My EK feels different after ASR Subframe and CTR Sway install ?
Old Feb 23, 2007 | 01:19 PM
le0ftw's Avatar
KOBE IS GOD
Default My EK feels different after ASR Subframe and CTR Sway install ?
It's more bouncy than ever. What could cause it to be more bouncy just with a sway install ? It was a bit bouncy before but that was fine, now its worst.
Old Feb 23, 2007 | 01:23 PM
blk_EK's Avatar
Default Re: My EK feels different after ASR Subframe and CTR Sway install ? (Leo24)
bump
Never heard of that from a swap bar install?!
How's your shocks n' struts holding up?
Old Feb 23, 2007 | 01:24 PM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Leo24 &raquo;</TD></TR><TR><TD CLASS="quote">It's more bouncy than ever. What could cause it to be more bouncy just with a sway install ? It was a bit bouncy before but that was fine, now its worst.</TD></TR></TABLE>
ok, is the ride "bouncy" OR "harsh"? adding large sway bars does make the car ride rougher, if thats what you mean, then yes its normal.
Old Feb 23, 2007 | 01:29 PM
Eran's Avatar
HT White Ops
To the thread title: Duh.
To the thread topic:
Your ride is going to be harsher because your lower control arms are working, more or less, as one solid unit. You may be confusing float with heavy dampening.
Old Feb 23, 2007 | 01:45 PM
le0ftw's Avatar
KOBE IS GOD
My bro (EKJAVI) whole setup is
KSport Coilovers
Ksport LCA's
ASR Plate
CTR Sway Bar
Cusco front and rear towers
and yes the ride is more harsh not more bouncy . I explained myself wrong, sorry.
Modified by Leo24 at 5:27 PM 2/23/2007
Old Feb 23, 2007 | 02:02 PM
Malakai's Avatar
it wasnt going to get softer. Im sure you had to know that generally when going for performance u lose comfort.
Old Feb 23, 2007 | 02:07 PM
le0ftw's Avatar
KOBE IS GOD
Default Re: (Malakai)
It's already a harsh ride I just thought I might have done something right.
Old Feb 23, 2007 | 02:08 PM
GarageAlchemist
Guest
Posts: n/a
your setup is pretty track man, are you running 40 series tires ?.. i'd get some 15x8's with some 50 series sidewalls, helps a lot and a lot better traction than some street radial
Old Feb 23, 2007 | 02:13 PM
le0ftw's Avatar
KOBE IS GOD
Default Re: (GarageAlchemist)
Here is a pic of the car and the tires on it;
It has a spooner exhaust on now and the bar and the ctr sway installed.
Ekjavi owns it btw my brother
I messed up on the title
Old Feb 23, 2007 | 03:22 PM
SoCal EJ1's Avatar
I have a similar setup to you, and as for the brace and sway, what you're feeling is what you should be feeling. when you hit bumps or ruts in the road, you're gonna feel them. The whole point is to stiffen up the feel of the car, which in turn sends vibration throughout the car.
Old Feb 23, 2007 | 03:24 PM
EkJavi's Avatar
* B A N N E D *
Default Re: (SoCal EJ1)
newer pics
Old Feb 23, 2007 | 04:24 PM
Archidictus's Avatar
Unceasing Measure
Default Re: (EkJavi)
A swaybar will increase the overall springrate of your rear suspension. Increased springrate makes for a harsher ride.
You should have expected this
Old Feb 23, 2007 | 04:27 PM
le0ftw's Avatar
KOBE IS GOD
Default Re: (Archidictus)
thanks people my brother appreciates it
Old Feb 23, 2007 | 04:37 PM
EkJavi's Avatar
* B A N N E D *
Default Re: (Leo24)
Old Feb 23, 2007 | 05:19 PM
MiamiEJ1's Avatar
Could be the Ksport, heard some people complain about them. Wild guess.
Old Feb 23, 2007 | 05:21 PM
le0ftw's Avatar
KOBE IS GOD
Default Re: (MiamiEJ1)
had em for over a year, I don't think its the problem.
Old Feb 23, 2007 | 06:56 PM
gato5254's Avatar
Default Re: (Leo24)
did you have to move the muffler up a bit because i got my ASR brace on and my ITR sway bar didn't fit and i'm going to move it a bit. i had the ITR sway bar on but didn't have that brace. but i did change my rear control arms to onmi power.
Old Feb 23, 2007 | 07:07 PM
Crx Jimmy's Avatar
you are basically adding spring rate when you add a bar, if your shocks are adjustable, adjust the rebound if its bouncy
Old Feb 23, 2007 | 07:08 PM
EkJavi's Avatar
* B A N N E D *
Default Re: (gato5254)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gato5254 &raquo;</TD></TR><TR><TD CLASS="quote">did you have to move the muffler up a bit because i got my ASR brace on and my ITR sway bar didn't fit and i'm going to move it a bit. i had the ITR sway bar on but didn't have that brace. but i did change my rear control arms to onmi power. </TD></TR></TABLE>it was a perfect fit..
Old Feb 23, 2007 | 07:29 PM
gato5254's Avatar
maybe it is my muffler, i changing because i thought it was tooo round and huge, and the tip got bent from speed bumps. but thanks for the info.
Old Feb 23, 2007 | 07:33 PM
eg:R's Avatar
i stick to oem gsr sway bar for my eg. drive normal
sky9's Avatar
u got any full pics of the car, i would love too see how it sits.
Old Feb 23, 2007 | 10:13 PM
jdm_dc_fan's Avatar
From: "That one guy with that one car" Kennewick WA
^^^ x2
Old Feb 23, 2007 | 10:34 PM
le0ftw's Avatar
KOBE IS GOD
Default Re: (jdm_dc_fan)
here is a really old pic
Old Feb 24, 2007 | 12:05 AM
Timmay's Avatar
Default Re: (Leo24)
im about to install my ASR with CTR .. i cant wait
