Torque Spec For Fuel Rail Mounting Nuts?
Old Feb 23, 2007 | 11:29 AM
BEE1's Avatar
Default Torque Spec For Fuel Rail Mounting Nuts?
Torque Spec For Fuel Rail Mounting Nuts? Haynes says 108 ft/lbs*seems a lot* and the Helms doesn't say. And also how tight does the fuel pulsation damper have to be?
Old Feb 23, 2007 | 03:56 PM
Mikey3000's Avatar
Default Re: Torque Spec For Fuel Rail Mounting Nuts? (BEE1)
that must be in-lbs. i don't torque mine any more than 15 ft-lbs.
Old Feb 23, 2007 | 04:45 PM
EG civic's Avatar
108 ft/ lbs wow! I think that would break the bolts pretty fast if u tried to tighten it that much. Yes that has to be in in/lbs there are 12 in/lbs in one ft/lbs so divide by 12 if converting in/lbs to ft/lbs and multiply by 12 if converting ft/lbs into in/lbs. So should tighten to about 9 or so ft/lbs.
Old Feb 23, 2007 | 08:31 PM
BEE1's Avatar
yea my thoughts exactly just making sure. how tight do you tighten the fuel pulsation dampner? you know the lil gizmo to the far left of the fuel rail on b16's?
grjr
Honda Civic (2001 - 2005)
Jul 29, 2011 11:12 PM
98Accord250K
Jun 9, 2010 10:59 PM
new_climber
Jan 21, 2009 06:18 AM
turboH22Aakkord
Aug 23, 2005 07:05 AM
