1989 CRX HFs are the worst for seat swapping?
I've done a lot of searching on the CRX seats conundrum and am only asking for a little reassurance-- so don't post any of that "do some searching" because if you read what I've concluded, you'll understand that I have searched!
Let me know if any of this is all correct for CRX's
90-91 CRX Seats all interchange with no mods.
88 (all models) and 89 (HF only) can be swapped with no mods.
89 (non-HFs) interchange with no mods.
*Also, some people have said that the seatbelt locations also have to be the same for the seats to swap without mods.
*I've also read that some 89 CRX's that were manufactured late in the year may have the 90 CRX seats (which would mean they could be swapped with any 90-91 CRX).
I guess also that some 90 CRX's might have the same (but oposite) problem.
So does this mean my CRX HF 1989 is possibly the absolute worst year/model of CRX to swap seats into?
TIA
Zack,
TIA
Zack,
this only works for US spec CRX's
88 crx all interchange with each other
89 HF can swap with 88
89-91 swap with each other
however, the rest of the world including canada all seats can swap from 88-91, and they are the same as the US spec 88 and 89 HF only.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TEGsrSC »</TD></TR><TR><TD CLASS="quote">90-91 CRX Seats all interchange with no mods.
So does this mean my CRX HF 1989 is possibly the absolute worst year/model of CRX to swap seats into?</TD></TR></TABLE>
No. There are only 2 types of '88-91 CRX seat mounts (rails and floor pan): those for cars with door-mounted seat belts, and those for cars with pillar-mounted seat belts. They are not interchangeable unless you swap seat pans.
CRXes with pillar-mounted belts include all '88 trims and the '89 HF.
CRXes with door-mounted belts include '89 DX, '89 Si, and all '90-91 trims.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TEGsrSC »</TD></TR><TR><TD CLASS="quote">do all the Canadian CRXs have the seatbelts on the pillars?</TD></TR></TABLE>
Yes.
The only CRXes to have door-mounted seat belts were the '89 USDM Si and DX, and all '90-91 USDM models. Models not intended for the USDM in those years had pillar-mounted belts.
Stop bumping.
Yes.
Stop bumping.
EF_338
Mar 4, 2007 04:30 PM
Jared
Nov 8, 2003 09:04 PM
