B18C + EF Wiring harness adapter (Help needed!)
Old Feb 23, 2007 | 09:35 AM
Nick_Drake's Avatar
Default B18C + EF Wiring harness adapter (Help needed!)
Backstory:
I'm no wiring guru, and it kinda makes me dizzy reading about all the choices out there that could potentially fix my problem so hopefully someone here can help me out.
Right now, I have an '89 HF up on blocks with an obd1 GSR in it. Now I have the ECU from the GSR and the ECU harness adapter so that's all taken care of.
Now then, my problem is that I don't know what to buy so that I can plug the engine harness off of the GSR into the plugs that are in the engine bay from the HF.
This would help me out so much if you could just point me in the direction of a plug and play adapter, as I hate wiring and don't want to muck anything up.
Thanks in advance guys.
Old Feb 23, 2007 | 11:08 AM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: B18C + EF Wiring harness adapter (Nick_Drake)
Go to synapse motorsport in Charleton, NY. They can get this done for you.
Or call Rywire. They can help you also.
Old Feb 23, 2007 | 07:01 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: B18C + EF Wiring harness adapter (mar778c)
don't bother just use a distributor adaptor harness for OBD0-1 or swap the plugs from the HF's distributor over to the GSR's, use a subharness for VTEC solenoid, VTEC pressure switch, Knock sensor, IAB's, and 4 wire O2. And then swap the OBD1 injector plugs from the GSR harness over to the HF's.
Old Feb 24, 2007 | 07:45 AM
Nick_Drake's Avatar
Default Re: B18C + EF Wiring harness adapter (HondaPartsHero)
Hey HondaPartsHero, I just looked at your ebay store and your idea makes much more sense to me. I'm buying it now thanks bro.
(EDIT: PM'ed you as I'm having trouble checking out through ebay)
Modified by Nick_Drake at 9:14 AM 2/24/2007
Hayden_Fourroux
Feb 2, 2016 09:01 PM
88efhatchstd
Nov 25, 2014 04:32 PM
sepetinswenze
Nov 25, 2010 05:25 AM
csubucky19
Jul 27, 2007 09:46 PM
