I need definitive answers on OEM LSD problems and rebuild
Old Feb 23, 2007 | 04:54 AM
RTW DC2R's Avatar
Default I need definitive answers on OEM LSD problems and rebuild
The archives have given me about 20 different answers regarding the OEM LSD malfunction and rebuild and I hope to get definite answers here. Im trying to find out if an OEM LSD can go bad over time, or if its just something that works, or doesnt work. Then I need to know if it can be rebuilt and whats involved in the rebuild. I am trying to dianose some issues and need to rule out the LSD, hopefully.
Most seem to say it either works or it doesnt. But some people say it can be something that worsens over time. What are the signs of an OEM LSD going bad (if there are any)? I know mine is still working (at least partially) since I can do 2nd gear burnouts from a roll and see two rubber streaks on the road in my mirror.
Secondly, what is involved in rebuilding an OEM LSD? I dont want to crack mine open without having a good idea of what is involved in fixing or refreshing it. Ive seen the long post with the Quaife LSD rebuild but I dont know if the process is the same with the OEM LSD.
Old Feb 23, 2007 | 04:56 AM
Dave_B's Avatar
Yes they can be rebuilt.
Contact user Rene M, he used to get rebuilt ones for $300. They may still do that.
Oh, and check the tires first, it's probably just the pressure is low...
Old Feb 23, 2007 | 05:58 AM
ebelp's Avatar
Default Re: I need definitive answers on OEM LSD problems and rebuild (RTW DC2R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R &raquo;</TD></TR><TR><TD CLASS="quote">What are the signs of an OEM LSD going bad (if there are any)? </TD></TR></TABLE>
Jack up the front of your car and spin one of the front tires...the other front tire should spin in the opposite direction. I'm assuming this won't happen if the LSD has failed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I know mine is still working (at least partially) since I can do 2nd gear burnouts from a roll and see two rubber streaks on the road in my mirror. </TD></TR></TABLE>
Best test evAr!!!
Old Feb 23, 2007 | 07:21 AM
94rs-turbo's Avatar
Yaah I would like to know what would need to be used to rebuild one becasue I have a busted one for sure
Old Feb 23, 2007 | 07:26 AM
walker111's Avatar
Default Re: (94rs-turbo)
I just checked Baranco site and didnt see that they sold the internal pieces seperately. Whay not just open it and check for extremely worn/broken/fractures in the pieces.
Old Feb 23, 2007 | 11:03 AM
citrus3000psi's Avatar
Old Feb 23, 2007 | 11:12 AM
RTW DC2R's Avatar
Thanks for the diagram. Too bad my trans is already out of the car. Im curious what the effects would be while driving for an out of service limit on the rotating torque check.
Old Feb 23, 2007 | 11:53 AM
walker111's Avatar
Default Re: (RTW DC2R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the diagram. Too bad my trans is already out of the car. Im curious what the effects would be while driving for an out of service limit on the rotating torque check. </TD></TR></TABLE>
I'm curious too, although that check seems to say that the idea of it either works or doesnt, is not exactly true.
Old Feb 23, 2007 | 12:12 PM
RTW DC2R's Avatar
Default Re: (walker111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">
I'm curious too, although that check seems to say that the idea of it either works or doesnt, is not exactly true.</TD></TR></TABLE>
exactly. and if its not working properly, what are the symptoms and what parts are replaced. I assume there are some guts in there but I never saw the inside of one and dont want to crack mine open til I know.
Old Mar 26, 2007 | 10:25 AM
Bill_Ee9's Avatar
Default Re: (I love lamp.)
i think that, by doing what the manual says, you just make sure that the LSD works as a differential, and not specifically as a Limited Slip Differential..
From my short experience if you jack up the car in neutral, and you rotate the one wheel, the other will rotate in the same direction (if you have lsd) and in the opposite if you dont. Is that correct? Can anyone verify it?
Old Mar 26, 2007 | 10:30 AM
walker111's Avatar
Default Re: (Bill_Ee9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bill_Ee9 &raquo;</TD></TR><TR><TD CLASS="quote">i think that, by doing what the manual says, you just make sure that the LSD works as a differential, and not specifically as a Limited Slip Differential..
From my short experience if you jack up the car in neutral, and you rotate the one wheel, the other will rotate in the same direction (if you have lsd) and in the opposite if you dont. Is that correct? Can anyone verify it?</TD></TR></TABLE>
No, that is incorrect. ITR lsd will spin in opposite directions. Clutch pack/welded diff will spin in the same direction.
Old Mar 26, 2007 | 10:34 AM
Bill_Ee9's Avatar
my bad, you are right
halfakneegrow
Northern California (Sales)
Apr 15, 2014 10:26 AM
bigcity84
Mar 8, 2007 09:18 AM
monicle
Nov 26, 2003 07:21 AM
.jacob
Jul 23, 2003 09:18 AM
