OMG not MORE trouble!!!! :'(
Old Feb 22, 2007 | 11:23 PM
taking-back-sunday07's Avatar
Default OMG not MORE trouble!!!! :'(
Ok...Pulling the motor from my rex and i addressed the hub nut issue but now i'm having more difficulties...The shift linkage has to be removed from the tranny, BUT: the pin is stuck, not allowing me to remove the linkage from the transmission. It does'nt seem to want to come out from the top nor the bottom. I have used hammers, screwdrivers AND hammers, and everything in between. Anyone have any suggestions? This motor swap is starting to suck...
Old Feb 22, 2007 | 11:37 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: OMG not MORE trouble!!!! :'( (taking-back-sunday07)
use an 8mm punch. should be a couple dollars at sears or somewhere..
Old Feb 22, 2007 | 11:46 PM
mra4886's Avatar
looks like you ran into the bitch pin. good luck hope you get it out. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sanimalp &raquo;</TD></TR><TR><TD CLASS="quote">use an 8mm punch. should be a couple dollars at sears or somewhere.. </TD></TR></TABLE> this is what works the best.
Old Feb 23, 2007 | 07:06 AM
dr_latino999's Avatar
Default Re: OMG not MORE trouble!!!! :'( (mra4886)
Time to be smarter than the transmission Disconnect the shifter from the car, drop and take with the transmission.
Old Feb 23, 2007 | 07:24 AM
Loserkidwac's Avatar
Default Re: OMG not MORE trouble!!!! :'( (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">Time to be smarter than the transmission Disconnect the shifter from the car, drop and take with the transmission.</TD></TR></TABLE>
Exactly what I said...it is also 1X easier to pop the pin out with the trans out of the car....
and yea 8mm punch and a hammer shoud get it out....I remeber on here someone made a tool with a "C" clamp with a punch welded to the to of it and a "cup" on the bottom...pretty much pressed the pin out into the "cup" awesome idea...i will eventually make one
Old Feb 23, 2007 | 09:10 AM
mar778c's Avatar
Community Builder
Community Influencer
Like Dr. Latino said, disconnect the linkage from the car. Then pull the motor and tranny together.
Old Feb 23, 2007 | 10:15 AM
Default Re: OMG not MORE trouble!!!! :'( (mar778c)
I did disconnect the linkage from the car, and I WOULD have pulled it all out BUT...when you try to lift the motor and tranny out of the car, the linkage catches the frame of the car (just under the firewall) and doesnt let you lift the motor up any farther with the entire linkage attached. If I were able to jack up the car further this would be possible, but I can't.
Old Feb 23, 2007 | 10:19 AM
ED9man's Avatar
Don't reuse the pin
Old Feb 23, 2007 | 10:22 AM
mar778c's Avatar
Community Builder
Damn, get some wooden blocks and stick on top of the jack. That will get you more elevation. Also use jack stands once you've get the car to the right height.
Old Feb 23, 2007 | 10:32 AM
Default Re: (ED9man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ED9man &raquo;</TD></TR><TR><TD CLASS="quote">Don't reuse the pin</TD></TR></TABLE>
Why not??
Old Feb 23, 2007 | 11:03 AM
JOE BD-0's Avatar
d<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by taking-back-sunday07 &raquo;</TD></TR><TR><TD CLASS="quote">....when you try to lift the motor and tranny out of the car, the linkage catches the frame of the car (just under the firewall) and doesnt let you lift the motor up...........</TD></TR></TABLE>
Why not just drop the motor and trans out from the bottom? just an idea....good luck...
Old Feb 23, 2007 | 11:11 AM
HBK's Avatar
HBK
Default Re: OMG not MORE trouble!!!! :'( (JOE BD-0)
I use an a/c bolt, the same size as the bolt that screws the other half of the shift linkage in. Line that sucker up, soak the pin in some pb blaster, and hammer away with a decent size sledgehammer. I guess I've done so many swaps that my bitch pin slides in and out like an asian in Jenna Jameson
Old Feb 23, 2007 | 11:14 AM
91ed9's Avatar
Default Re: OMG not MORE trouble!!!! :'( (HBK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HBK &raquo;</TD></TR><TR><TD CLASS="quote"> I guess I've done so many swaps that my bitch pin slides in and out like an asian in Jenna Jameson </TD></TR></TABLE>
Thats funny as hell.... but yea it should come out with ome bp blast or wd40 maybe even try soap and water!
have fun!
Old Feb 23, 2007 | 11:22 AM
khoalie's Avatar
Default Re: OMG not MORE trouble!!!! :'( (91CRXed)
if you have access to an air compressor, an air hammer will do it in literally a few seconds, just have to find the right bit
Old Feb 23, 2007 | 12:50 PM
Default Re: OMG not MORE trouble!!!! :'( (khoalie)
I have an air hammer somewhere around here. I'll look for it later and see what I can do.
Old Feb 24, 2007 | 01:12 PM
I got in last night around 2am and decided to get to work lol...I found my air hammer, put a punch-type bit in it, and hammered that son a beast till it got about 3/4 of the way out(my bit was'nt long enough). After that, i grabbed it with some vice-grips and shook and jerked the pin until it came out...I WAS A HAPPY CAMPER! Thanks for the ideas guys! Honda-Tech rocks
Old Feb 24, 2007 | 01:52 PM
blah13's Avatar
****, first time I did a swap I had everything out except the mounts and linkage and I ran into the bitch pin. I hammered away with no luck, so I got creative. A 1/2" to 3/8" wratchet adapter fits right into the bitch pin. So I set this adapter on my 3 ton floor jack and positioned the adapter right under the bitch pin and proceded to jack up the whole front end of the car on the bitch pin alone. Still no budge, so I sprayed some PB blaster on there and let it set. I then climbed into the engine bay, and stood on the crossmember and bounced up and down. Needless to say I nearly fell out backwards when the pin popped out. It worked, was funny as ****, and I didnt get hurt so win/win.
p.s. Dont do what I did, though if you do, video tape it, I wish I had.
Old Feb 25, 2007 | 11:19 AM
Default Re: OMG not MORE trouble!!!! :'( (blah13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blah13 &raquo;</TD></TR><TR><TD CLASS="quote">p.s. Dont do what I did, though if you do, video tape it, I wish I had.</TD></TR></TABLE>
lol
Old Feb 27, 2007 | 10:47 PM
haha omg...I moved my car in my garage and I LOST THE DAMN "BITCH PIN"...now I have to find somewhere to get another one....this sucks
Old Feb 28, 2007 | 06:36 AM
http://www.acuraoemparts.com/d...ch=no
#28 there are 2 listings for it go to your local dealer and ask for either part number or order it from that site they usually have the best prices but there is like a standard $5 shipping rate so maybe order some other things too...
028 94305-80202 PIN, SPRING (8X20) 1 1990 INTEGRA 0.95 0.76
028 94305-80222 PIN, SPRING (8X20) 1 1990 INTEGRA 1.12 0.90
Old Feb 28, 2007 | 08:22 AM
ILcrxsi1's Avatar
I tell doctors what to do
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by taking-back-sunday07 &raquo;</TD></TR><TR><TD CLASS="quote">I got in last night around 2am and decided to get to work lol...I found my air hammer, put a punch-type bit in it, and hammered that son a beast till it got about 3/4 of the way out(my bit was'nt long enough). After that, i grabbed it with some vice-grips and shook and jerked the pin until it came out...I WAS A HAPPY CAMPER! Thanks for the ideas guys! Honda-Tech rocks </TD></TR></TABLE>I'm sure the neighbors liked the air hammer at 2am
Old Feb 28, 2007 | 10:35 AM
Kaan's Avatar
Loved
Community Favorite
Default Re: OMG not MORE trouble!!!! :'( (ILcrxsi1)
i used a 5mm hex head wrench from the $3 harbor frieght set and a hammer... it came right now! who needs an 8mm punch?
Old Feb 28, 2007 | 01:39 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILcrxsi1 &raquo;</TD></TR><TR><TD CLASS="quote">I'm sure the neighbors liked the air hammer at 2am </TD></TR></TABLE>
Haha..they were probably more upset over my loud radio blaring rock music lol.
Old Feb 28, 2007 | 02:05 PM
92civicfreak's Avatar
what i did is i took a metal dowel... roughly 1-2 ft long & hammered the pin out w/ the dowel in the engine bay.... i did have to take a dremmel & grind it down to fit, but since then... i have never had a problem... yea... i'm a smart mo fo.... GOOD LUCK!
Old Feb 28, 2007 | 02:09 PM
goforbroke's Avatar
MEAT PATTY
I always use a 1/4 ratchet extension and a hammer, works every time. I don't like pounding away on the shaft like that. Your pretty crazy using a air hammer.
ryc555
Jul 14, 2007 10:46 PM
Xemu
10
Apr 6, 2007 03:36 PM
DC2 Mang
May 4, 2006 02:18 PM
civic889802
12
Jan 1, 2006 12:20 PM
drewek-9
Apr 11, 2004 10:33 AM
