Also new, VTEC sub harnesses and Shocktower/ECU pin wires!
Also new is our VTEC sub harnesses and Shocktower pin wires. As with our tuck harnesses, 18ga wire is used for these and all joints are soldered/heatshirinked. The VTEC subharnesses are made to order and besides VTEC solenoid and Oil pressure switch, we can add knock sensor, 4-wire o2 sensor and IAB's. These also come with the ECU pins attached so these are truly plug and play!.
Our Shocktower pin wires make it easy to utilize a VTEC engine harness on a non VTEC equipped chassis. You simply plug in the VTEC harness to your chassis harness and then use these wires to connect the new sensors from your shocktower plug to your ECU!
projecthonda
Feb 23, 2007 06:48 PM
