Toda Header
I have a 98 spec itr and have just purchased some toda headers of EBAY. Now the auction says that these headers will fit both 96 and 98 spec. Just want to confirm if fitting headers to a 96 or 97 spec is any different to 98 spec itr's??
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM96R »</TD></TR><TR><TD CLASS="quote">Cheers, because by the time i look through all those links someone will have stated why the "exhaust manifolds" are different in 1 sentence...but meh
thanks anyway</TD></TR></TABLE>
The blocks are the same. That is not what the seller was referring too. There are subtle differences in the suspension and gearing mainly on the 98 ITR. That is more or less all they are referring too.
the difference between 96 and 98 spec is the header bracket that's near the collector, 98 spec uses an aluminum bracket while 96 spec ( along with usdm) uses a stamped steel bracket. the bolt spacing on both are different, so i don't see how your toda will fit both, unless you don't bother using the bracket. can you give me a link to the ebay auction?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando »</TD></TR><TR><TD CLASS="quote">What's a headers and why is it plural? Headers are for V8's. Toda makes an Exhaust Manifold.</TD></TR></TABLE>
And a race header
It's just like everyone calling it a wing on the car. Planes have wings, cars have spoilers....
But yea, it's not plural bud. There is only one header for a 4 banger. 2 for V-6's and V-8's
And a race header
Bit of a bugger as I have already purchased it. Still don't know if it is for the 98 spec or not as the seller has not told me for sure. He still maintains it will fit both!
If it doesn't fit then somebody in NZ will be getting a cheap Toda header!!
Can you re drill the bracket holes to fit the mountings?
Cheers
Cheers
If your bracket doesn't work, you can always buy the bracket from a 98+ ITR and use that. I have a Toda header on mine and I'm not currently using the bracket.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6-DC2 »</TD></TR><TR><TD CLASS="quote">If your bracket doesn't work, you can always buy the bracket from a 98+ ITR and use that. I have a Toda header on mine and I'm not currently using the bracket.</TD></TR></TABLE>
I had a toda header and didn't use it either
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B »</TD></TR><TR><TD CLASS="quote">
And a race header
But yea, it's not plural bud. There is only one header for a 4 banger. 2 for V-6's and V-8's</TD></TR></TABLE>
planes also have spoilers...and wings and ailerons and elevators...whats your point. trying to point out when some wrong only works if you are right....
you're not
And a race header
you're not
they have arrived and are 98 spec but they do not have those clip looking things on the downward (vertical) part of the piping. Do all toda exhaust manifolds have these???....or a mine potentially fake???
Cheers
Cheers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JasperDA9 »</TD></TR><TR><TD CLASS="quote">
you're not</TD></TR></TABLE>
...uhhhh, yeah. and?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Parada »</TD></TR><TR><TD CLASS="quote">
...uhhhh, yeah. and?</TD></TR></TABLE>
yah well V10s, V12s and V16s have headers too
gutmann
Sep 18, 2004 03:01 PM
