Clutch question d15
Old Feb 22, 2007 | 09:08 PM
mrpackrat's Avatar
Default Clutch question d15
Hello, I have a 90 civic with a d15 motor, and the trans is bad, I just got a tranny from an 88 model. My question is can I use the 88 disc with the 90 pressure plate and flywheel(due to the disc being 21 spline instead of the 20 spline of the input shaft)-or would it be better to put the input shaft in from the 90 tranny(and how hard is that?). Thnaks
Old Feb 22, 2007 | 09:19 PM
dr_latino999's Avatar
Default Re: Clutch question d15 (mrpackrat)
If you have a 88 transmission, and you would like to use a 90 Flywheel and pressure plate you will need the clutch disk from a 86-89 Accord.
Old Feb 22, 2007 | 09:24 PM
mrpackrat's Avatar
Default Re: Clutch question d15 (dr_latino999)
Thank You sir!!!
90_EX_Civic
Mar 1, 2010 07:02 AM
deadon
Mar 22, 2006 06:11 PM
PaImportTuner
11
Jan 16, 2004 09:49 AM
Toptul_Honda
Feb 15, 2003 11:48 PM
memphiss13
Feb 7, 2003 02:33 PM
