How does this sound???
Ok, first does any one know how to remove the cover on the seat belt not buckled warning lights housing?It's were the rear view mirror is.After my Delsol seats are installed my warning lights will not be applicable since it doesn't plug into the new seats.So I was thinking of using the power that is located up there, to power a RADAR detector, attached to the housing cover.Hard wiring it in.Does any one think this will work and how do I get the cover off?
Later-HC4G
Later-HC4G
you can just push on one side of the cover while pulling and gently prying the other side, try not to use any tools, you fingers should be able to wiggle it loose. that is a good idea, hardwiring a radar detector off of that. it would be better than splicing into a different circuit anyway.
MaretronJohn
Sep 6, 2013 11:40 AM
