Startup troubles
Old Feb 22, 2007 | 07:49 PM
cclarke1's Avatar
Default Startup troubles
Okay so heres the deal. Earlier this morning I took my car out to get some groceries and it ran fine. Then I tried to take it out later that night and it wouldn't start. All I heard was a clicking noise and the lights on the dash flickered. I don't think its the battery because the stereo works just fine while I have it on acc. Could it be the alternator? Oh and by the way its a 92' Accord EX. Thanks alot in advance!
Old Feb 22, 2007 | 08:07 PM
pos_cd5's Avatar
Default Re: Startup troubles (cclarke1)
check the starter and make sure all its wires are on tight
Old Feb 22, 2007 | 08:32 PM
02 accord's Avatar
Could be a dying battery. Take it to autozone and have them test it. You can't compare your stereo to the starter. Stereo = 20 amps, starter = 200+ amps.
Old Feb 23, 2007 | 04:36 AM
75thRanger's Avatar
Default Re: Startup troubles (02 accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02 accord &raquo;</TD></TR><TR><TD CLASS="quote">Could be a dying battery. </TD></TR></TABLE>
I agree, if your still hearing the clicking it should be that the starter isnt getting enough juice. This happened to my friends car and we just had to jump it to get it going.
Old Feb 24, 2007 | 10:18 AM
cclarke1's Avatar
Well I thought it was the battery too but when I jumped it from my friends ford ranger it still did the same clicking noise. Maybe I'll take the batt out and bring it somewhere for a test. I'll let you all know on the results. Thanks.
Old Feb 24, 2007 | 10:28 AM
sony224422's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cclarke1 &raquo;</TD></TR><TR><TD CLASS="quote">Well I thought it was the battery too but when I jumped it from my friends ford ranger it still did the same clicking noise. Maybe I'll take the batt out and bring it somewhere for a test. I'll let you all know on the results. Thanks.</TD></TR></TABLE>
theres your problem right there
jk, jk. If your starter is still clicking, make sure that the connections are good from the other car. If you don't get a good ground it won't help at all, and you should be able to tell when it gets a good connection because you'll hear/see the other cars alternator kick on to charge your battery.
xjm92x
16
Mar 22, 2011 02:58 PM
MID0RI
Apr 17, 2009 06:35 PM
importfanatic17
Feb 26, 2007 12:34 PM
EdBoon
12
Aug 7, 2005 06:57 PM
pecusio
Aug 16, 2004 06:50 AM
