My first manifolds
not bad let us know how it performances some tis in case you wanna change performance make the intake runners longer for more torque on the low end right now from eye balling your set-up its gonna be good for high high rpm HP but you may suffer big on the torque end. also the placement of your injectors is import to your A/F ratio so when tuning monitor that. also a good rule of tumb when building any intake manifold is that the total volume should be around or a LITTLE more than 1/2 liter of the engines total liter so if you got a 2.0l you may want to size the intake manifold to around 1 liter other than that nice welding
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony413 »</TD></TR><TR><TD CLASS="quote">not bad let us know how it performances some tis in case you wanna change performance make the intake runners longer for more torque on the low end right now from eye balling your set-up its gonna be good for high high rpm HP but you may suffer big on the torque end. also the placement of your injectors is import to your A/F ratio so when tuning monitor that. also a good rule of tumb when building any intake manifold is that the total volume should be around or a LITTLE more than 1/2 liter of the engines total liter so if you got a 2.0l you may want to size the intake manifold to around 1 liter other than that nice welding </TD></TR></TABLE>
Truthfully, those VW engines arent really lacking torque. Especially the R32.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GTibunny16v »</TD></TR><TR><TD CLASS="quote">
Truthfully, those VW engines arent really lacking torque. Especially the R32. </TD></TR></TABLE>
not a fan of the R32 almost made the mistake of buying one untill i got blown away by an STI while on a test drive
