High Compression Numbers?
I have a H22A (of some kind, if you've seen my other thread-haha), and the compression is 260 all the way across. There all the same, so I would suspect that the compression is this high for a reason.
What compression pistons would make my compression this high? Or could it have Type-S pistons? What does a normal Type-S H22 generally have as far as compression numbers?
Would the Type-S motor have anything different then the normal H22A's as far as cosmetics or anything?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoN2DaSoNz »</TD></TR><TR><TD CLASS="quote">yes type s pistons are a bigfactor for hp gains on the h22's compare to USDM and JDM motor heard the Type S are more reliable and HP friendly =]</TD></TR></TABLE>
next time try to learn proper english skills.
HP friendly? pretty general term seeing as if one was running different setups (turbo or NA), type s pistons might be a negative eh?
EG type GTR
Jul 28, 2006 11:41 PM
d98clturbo
Nov 9, 2003 12:10 PM
