fuel injector flow rates for a crx si 1.6 and an hf 1.5
Old Feb 22, 2007 | 05:21 PM
hondacivic90zc's Avatar
Default fuel injector flow rates for a crx si 1.6 and an hf 1.5
does anybody know what the fuel flow rates are on each injector (the 1.6 si injectors compared to the 1.5 hf injectors)
the reason is that i have a 88 crx dx and i converted from DPFI to MPFI with 1.6 injectors and the car runs rich and it sometimes throws a code for an o2 sensor. You can smell the excess gas when i get on it.
If anybody knows i would appreciate the help.
Thanks
Old Feb 22, 2007 | 06:37 PM
ef-you's Avatar
Default Re: fuel injector flow rates for a crx si 1.6 and an hf 1.5 (iandavis90)
have you done a thurough inspection? Check for vacuum leak? Did you use a new intake manifold gasket? We need more info?
Old Feb 22, 2007 | 06:56 PM
Default Re: fuel injector flow rates for a crx si 1.6 and an hf 1.5 (ef-you)
yes i did put on a new intake manifold gasket and as far as i know it does not have a vacuum leak
89hondacivicdx
Sep 19, 2011 06:59 AM
hondacivic90zc
11
Mar 1, 2007 02:29 PM
333
Feb 8, 2003 01:29 PM
Crxfanatic15
10
Jan 16, 2003 10:49 PM
1990hondaHF
Jul 23, 2002 12:50 AM
