How hard is it to cut sidemarker holes?
Old Feb 22, 2007 | 01:43 PM
truevietluv636's Avatar
Default How hard is it to cut sidemarker holes?
im thinking about getting sidemarkers for my eg. Anyone ever fuked up the fenders trying to cut the holes out? or have any hard *** time doing it? this would be my first time cutting something like this and just want some tips so i dont mess up. is it easy to do a clean job and have it look perfect and oem? a dremel is the best way to cut it right?
Old Feb 22, 2007 | 01:45 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: How hard is it to cut sidemarker holes? (truevietluv636)
Take it to a body shop and give them a picture of another car with sidemarkers and tell them to drill the holes.
$20
Ek Forever y0!
Default Re: How hard is it to cut sidemarker holes? (ek forever guy)
Oh, and they are good at it, provided you take it to a reputable shop, Autobody world, Maaco, etc.
Old Feb 22, 2007 | 01:49 PM
BLUIZE256's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">Oh, and they are good at it, provided you take it to a reputable shop, Autobody world, Maaco, etc.</TD></TR></TABLE>
i dont know about where you live, but maaco in jersey is in no way reputable . .
**DOHC HaTcH**'s Avatar
take it to a shop ftw
i wouldnt dare try and cut a hole in my fenders
Old Feb 22, 2007 | 01:50 PM
Ek Forever y0!
Default Re: How hard is it to cut sidemarker holes? (**DOHC HaTcH**)
Maaco is fine. I got my car paintmatched there and turned out fine.
Just find a nice one in a nicer part of town like i did.
Old Feb 22, 2007 | 01:51 PM
thanks, good idea.
blackrag's Avatar
Maaco? Uhh.. I'd rather do it myself, honest. I have seen Maaco's work. (Paint only) And... Wow.. It was HORRID.. Really.
Old Feb 22, 2007 | 02:21 PM
94eh2's Avatar
Default Re: (blackrag)
well im no pro but have cut three cars fender so far for the side marker installs..pretty easy and most times came out decent but needed to use some bono for the lines at the ends..i used a air compressor and cutting wheel works like a charm ..but im sure a dremel would do it cleaner..i say go for it..gotta learn sometime..just line it up correctly and make sure you have the correct angles..ect...hope this helped
Old Feb 22, 2007 | 02:40 PM
Ek Forever y0!
Default Re: (305accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackrag &raquo;</TD></TR><TR><TD CLASS="quote">Maaco? Uhh.. I'd rather do it myself, honest. I have seen Maaco's work. (Paint only) And... Wow.. It was HORRID.. Really.</TD></TR></TABLE>
That's when you bitch at the owner and ask him if he would be happy with that paint on his car.
Then they repaint it.
For paint matching a fender or sideskirts maaco is perfectly fine.
Old Feb 22, 2007 | 02:46 PM
B18CivicEH2's Avatar
Default Re: (ek forever guy)
theres a template around that gives you the exact messurements...i used that...put masking tape on my fender and drew the messurements with a pencil...i used a dremel to cut the hole...this is how it came out.
Old Feb 22, 2007 | 02:48 PM
Ek Forever y0!
Default Re: (B18CivicEH2)
Do the regular instruction manuals wire them so that they come on when you turn your corners on? Or is that a "custom" thing?
I like seeing the sidemarkers that stay lit and blink brighter when turn signals are being used.
Old Feb 22, 2007 | 02:56 PM
i dont thin you get instructions on how to wire them...but i've been seing alot of people ask on how to make light up with the corners and blink with them as well...i wired them to the corner blinkes..the 2 wires from my sidemarkers got tapped to 2 on the corner, BUT not to the ground wire from the corner..one was to the red and the other to the green wire......forgot exactly which wire went where though...try one way or the other...
Old Feb 22, 2007 | 03:01 PM
BLUIZE256's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CivicEH2 &raquo;</TD></TR><TR><TD CLASS="quote">i dont thin you get instructions on how to wire them...but i've been seing alot of people ask on how to make light up with the corners and blink with them as well...i wired them to the corner blinkes..the 2 wires from my sidemarkers got tapped to 2 on the corner, BUT not to the ground wire from the corner..one was to the red and the other to the green wire......forgot exactly which wire went where though...try one way or the other...</TD></TR></TABLE>
i like how it looks
i know it has nothin to do with the OP's question, just figured i'd throw it out there
Old Feb 22, 2007 | 03:02 PM
Eran's Avatar
HT White Ops
Dremel or metal nibbler from Radio Shack.
Old Feb 22, 2007 | 04:47 PM
Default Re:
is this the right template? do i just print this out and tape it to the car?
Old Feb 22, 2007 | 05:17 PM
pdiggitydogg's Avatar
http://www.hstuners.com/forums...23590
Old Feb 22, 2007 | 05:51 PM
krisjk2's Avatar
Default Re: (pdiggitydogg)
jdm is having them on with the parking lights and headlights; they also turn on and off alternating with the turn signals.
Old Feb 22, 2007 | 06:04 PM
Eran's Avatar
HT White Ops
Default Re: (Kris.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kris. &raquo;</TD></TR><TR><TD CLASS="quote">jdm is having them on with the parking lights and headlights; they also turn on and off alternating with the turn signals.</TD></TR></TABLE>
Actually .... JDM is having your corner and side markers off no matter what, and flashing in time with each other for turn indication.
Old Feb 22, 2007 | 06:05 PM
MiamiEJ1's Avatar
Default Re: (Kris.)
Your an idiot
Old Feb 22, 2007 | 06:22 PM
allricedout's Avatar
maaco is only as good as the autobody worker they hired.
everyone has two hands, use them. because no one else really cares about youre car as much as you do.
Old Feb 22, 2007 | 06:24 PM
simonsays's Avatar
New User
^ haha
Old Feb 22, 2007 | 06:26 PM
BlueIntegraBoy's Avatar
I used a drill to make a pilot hole, then used a metal nibbler (found at Radio Shack) to cut the template.
Old Feb 22, 2007 | 06:43 PM
Default Re: How hard is it to cut sidemarker holes? (BlueIntegraBoy)
is a metal nibbler more precise than a dremel? i never used a metal nibbler before and was wondering if it was easy to use and any muscle needed for cutting?
Old Feb 22, 2007 | 06:47 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by truevietluv636 &raquo;</TD></TR><TR><TD CLASS="quote">is a metal nibbler more precise than a dremel? i never used a metal nibbler before and was wondering if it was easy to use and any muscle needed for cutting?</TD></TR></TABLE>
It can be more precise and cleaner. It is easier to use, but takes longer to cut the hole. It takes some muscle to keep squeezing the handle.
