maybe a stupid question but what gasket to use with type s OS .25 pistons
is the normal oem h22 gasket sufficient or do they actually make a gasket for .25 over.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gaydm.accord »</TD></TR><TR><TD CLASS="quote">is the normal oem h22 gasket sufficient or do they actually make a gasket for .25 over.</TD></TR></TABLE>
stock gaskets are actually 1mm over the bore, so the one for the h22 is 88mm , thats why i use the f23 head gasket in the f22/h22 byrid, f23=86mm bore = 87mm head gasket.
so yeah there is plenty of room for your .25 over
Modified by prelittlelude at 11:17 AM 2/27/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelittlelude »</TD></TR><TR><TD CLASS="quote">
stock gaskets are actually 1mm over the bore, so the one for the h22 is 88mm , thats why i use the f23 head gasket in the f22/h22 byrid, f22=86mm bore = 87mm head gasket.
so yeah there is plenty of room for your .25 over</TD></TR></TABLE>
I may be wrong I always thought they were 85MM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Missing Gears »</TD></TR><TR><TD CLASS="quote">use the stock gasket.</TD></TR></TABLE>
werd
werd
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by md23vtec »</TD></TR><TR><TD CLASS="quote">
werd
whoops, ill fix that in my above post. .yes f23=86mm bore = 87mm bore head gasket
f22=85mm bore = 86mm bore head gasket
werd
</TD></TR></TABLE>whoops, ill fix that in my above post. .yes f23=86mm bore = 87mm bore head gasket
