Sohc/Dohc transmission vs. SI d Series trans. (difference)
Old Feb 22, 2007 | 09:11 AM
elecgenius's Avatar
Default Sohc/Dohc transmission vs. SI d Series trans. (difference)
how can i tell if i got an SI trans or a ZC trans?
Old Feb 22, 2007 | 06:14 PM
elecgenius's Avatar
Default Re: Sohc/Dohc transmission vs. SI d Series trans. (elecgenius)
elecgenius's Avatar
Old Feb 26, 2007 | 11:38 AM
elecgenius's Avatar
"still need to know"-bump
Old Feb 26, 2007 | 11:47 AM
FIGARILA's Avatar
do you mean zc (sohc) or zc (Dohc)
zc(sohc) should have the smaller diff. hole
zc(dohc) has the larger differential.
Old Feb 26, 2007 | 11:54 AM
elecgenius's Avatar
Default Re: Sohc/Dohc transmission vs. SI d Series trans. (FIGARILA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FIGARILA &raquo;</TD></TR><TR><TD CLASS="quote">do you mean zc (sohc) or zc (Dohc)
zc(dohc) has the larger differential.</TD></TR></TABLE>
well yeah...... i wanted to compare the soch, doch and SI... i think the sohc has the same diameter as the SI but the dohc has a bigger diff diameter then both right?. if thats the case how do i check if mine is the sohc zc instead of a n SI (i got it from a complete swap so i think its Sohc zc tranny. thanks for ur help in advance
ilovemyb16a
72
Apr 26, 2006 07:54 PM
JDM_EK_JOE
Jan 11, 2006 10:01 AM
mimesis
Apr 5, 2005 09:46 AM
Mr.c
13
Jun 14, 2004 06:54 PM
Ef Whore
Jan 29, 2003 03:59 PM
