F20B clearance using H22 Crower Stage 3 cams
I have F20B and using Crower stage 3 cams and would like to know if I have enough clearance between my valves and pistons especially when the V-tec kicks in. I'm using H22 Crower stage 3 cams.
thanks for the help.
thanks Jdogg. One query, how does the H22 crower stage 3 cams work with the F20b? I'm using the cams with Ferrea springs and retainers. Does the V-tec work well with these cams for this motor?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by machine4321 »</TD></TR><TR><TD CLASS="quote">i thikn as long as you have other GOOD mods to support the f20b, they should do fine . as long as they let the motor breath well up top </TD></TR></TABLE>
I think crower3s are way too much for a bolt on f20b....**** on my h22 with an open rmf header and a 70mm tb I only really gained hp way up top.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KMaxwell »</TD></TR><TR><TD CLASS="quote">i made pretty good power the whole way up the power band. peek was 8400-8500 and held the power all the way to 9400. Mine has plenty of breathing but its lack of comp. i think</TD></TR></TABLE>
howard was telling me about your car when i was there on tuesday... what'd it put down, i wana see the graph!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 »</TD></TR><TR><TD CLASS="quote">
I think crower3s are way too much for a bolt on f20b....**** on my h22 with an open rmf header and a 70mm tb I only really gained hp way up top.</TD></TR></TABLE>
and whats wrong with that suuuucka!?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked »</TD></TR><TR><TD CLASS="quote">
my h22 is for da street homez....I don't always get to race it like you do you lucky barstard....lol I want some torque.
Good numbers on the RLZ dyno man
I only made about 6 more than that before I did my cams.
</TD></TR></TABLE>my h22 is for da street homez....I don't always get to race it like you do you lucky barstard....lol I want some torque.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alterdcreations »</TD></TR><TR><TD CLASS="quote">f23 is 97mm stroke</TD></TR></TABLE>
its a beautiful thing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97LXF20B »</TD></TR><TR><TD CLASS="quote">kmaxwell -
I have an F20B in CD7 and I want to build it. Where do you get specs for all the head and block internals?
jinwoo -
are you just using all H22 valvetrain components?</TD></TR></TABLE>
should go for h22 or higher displacement .. accords are heavy, the more tq the better
jinwoo -
