which cams to buy
basically, i have a 2000 civic si with ls/v tec. i had my mind set on just ctr cams when i built the motor but now im thinking of a few other options. the car is a daily driver and im very picky about it. im not buildin the car to be a streight out race car. the only reason i built an ls/vtec is cause i blew my bottom end and had the ls bottom end laying around. i am running itr piston, and valve springs, every thing else is off the b16. also rod bolts and studs. i want to stay in the itr vavle spring set up. what do u guys think.
here are all the cams ive been looking into. not looking to spend over 600
ctr oem
skunk 2 stage 1
buddy club 3
brian crower stage 2
ctr oem
skunk 2 stage 1
buddy club 3
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice »</TD></TR><TR><TD CLASS="quote">Stock valvesprings, stock cams.</TD></TR></TABLE>
The Skunk2 Stage 1's are not so radical that the ITR valvetrain cannot support them.
Keep the revs conservative.
thanks for the input so far. i saw that the buddy club3 dont say anything about upgrading the valve train. also the brian crowers look to be inbetween skunk 2 stage 1 n 2s. but i dont no if its safe. im going to be pushing the motor till 8500.
my redline is 8800 but i dont push it that much
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Rob »</TD></TR><TR><TD CLASS="quote">
Keep the revs conservative.</TD></TR></TABLE>
...and not make as much power. OR you could spend the whoppin $250-300 bucks for good valvetrain and rev to where your car makes power. Turn around and sell your type r valvetrain for $150 and you've got a fatty $150 bucks out of your pocket. But no, that makes too much sense.
so where exactly do u think my car is going to make power. lets see the car is a DAILY DRIVER, and its also an ls/vtec,. last that i heard 8500 to 8800 rpm on this motor was a little high. i guess i should just get springs and retainers and rev to 9000, that really sound good.
but thanks agian d-rob for ur imput i think the skunk2s are what im going to go with
I seen valves bind at revs less than 8500 rpm. Do a search for B-series valves springs thread. There's a good write up on stock valve spring capabilities, and several aftermarket brands. That's what made me decide to ditch my itr vavlespring combo for some supertechs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda_ef9 »</TD></TR><TR><TD CLASS="quote"> seen them make power to 9200 with pro1s</TD></TR></TABLE>
Umm, no...not with Pro 1 's.
...and not make as much power. </TD></TR></TABLE>
Skunk2 Stage 1's will peak at like, 7800 RPM on an engine like the OP's.
I wouldn't say he'd be "not making as much power."
OR you could spend the whoppin $250-300 bucks for good valvetrain and rev to where your car makes power. Turn around and sell your type r valvetrain for $150 and you've got a fatty $150 bucks out of your pocket. But no, that makes too much sense. </TD></TR></TABLE>
Agreed, valvetrain prices really are so low these days that everyone should be able to scrounge together the funds for a good setup.
But, that wasn't the question. He asked which cams he should buy, I recommended a cam I had good experience with, and simply stated the fact that the Stage 1's need not valvetrain upgrade unless revving beyond the factory rev limit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ef_you_up »</TD></TR><TR><TD CLASS="quote">well as far as i know an ls/v, dd, and high revs dont really go hand in hand. can an ls/v even make power past 8k??</TD></TR></TABLE>
Funny, mine goes to 8800-9000 RPM daily...
- Derek
- Derek
- Derek
i guess what i am trying to say is that a dd should be reliable
and revving that motor so high like that is anything but that
- Derek
If he wants a realiable DD then some blox Type A cams will be well under $400 and with the extra money some supertech, or RM valves springs for $150, that's realiable and still under his $600 budget.
yes, i dont have them yet but....
SKUNK 2 STAGE 1 CAMS ..... seriously, i hear nothing but awesome news about them, im going to buy mine prob in june... just a suggestion
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ItsMeMiiiiike »</TD></TR><TR><TD CLASS="quote">do not get blox, they do not give as much power as skunk2....in cams, intake manifolds etc.
Hahahahahahahahahahahahaha
You've got to be kidding me.
</TD></TR></TABLE>Hahahahahahahahahahahahaha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ItsMeMiiiiike »</TD></TR><TR><TD CLASS="quote">hahahahahahahahahahahahahahaha
youve got to be gay...
You DO realize the cams are 100% the exact copies of the Skunk2's, right?
Let's see here...
If two sets of cams share identical lift and duration specs...
They make the same power!
What a brilliant deduction!
You're a ******* tool, irregardless of your agreement with me on the cam choice for the OP.
"What's in a name? Would a rose, by any other name, smell as sweet?"
- Derek
Let's see here...
- Derek
wow, I'm surprised noone recommends the BC3+. There are some dynos of them floating around OWNING the S2S1 all the way up to like 7800 rpms. The Skunks made a couple more up top but the BC3+ cam dominated through most RPM's. Either way, I would recommend a better valvetrain. If I use my BC3+ (I may go bigger), I'll be using ITR outers and portflow inners that I bought from JHP a while back. Good luck.
Modified by JAYSEM Society at 10:48 AM 2/26/2007
True.
I did not suggest the BC3+'s, simply because I have no personal experience with them.
But yes, I have seen many dynos proving what you're saying.
- Derek
- Derek
