timing help
i just did the timing belt on my 90 CRX si and after all said and done when i am setting up the timing with the light i have to have the dizzy all the way retarted to have the make almost line up where they are supose to (seems like it needs to be even more retarded) ... i have checked over and over the makes all line up on the tdc marks.. there are the like this if it works out
...................l l l.........l
................timeing......TDC
................l
...........my mark is here
when its all the way retarded??? when i advance it is just farther away???
seems to run fine but milage is shitty??
anyone had this problem or know of anything that could be off..
................l
i did jump that little blue connector but i did with and without and it dosnt do anything??.. i did set it with it jumpped but i dunno, is there anyway to tell if that connector works
and the cam TDC mark is bang on when #1 is at tdc aswell.. it is strange
now i have never has the actual cam gear off is there anyways it could not on the cam correct??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91TurboSir »</TD></TR><TR><TD CLASS="quote">
how do i check if the cam timing is on</TD></TR></TABLE>
take the valve cover off, rotate the crank till the tdc mark lines up with the ^ mark. then see if the line on the cam lines up with the ^ mark it is supposed to. your cam is probably one tooth off
The marks are on the gears. You have an arrow on each gear that say "UP" and when they both are up each cam gear has a little - and they should meet eachother so it looks like this - - when both arrows are pointing up
sageuvagony
Apr 5, 2007 05:47 AM
Frederz
60
Apr 20, 2004 11:04 PM
