H22A1 Head on my H23 Block.
yeah bro, idk myself i was browsing ebay stuffers. then i saw this...
http://cgi.ebay.com/ebaymotors...wItem
so i bought one of those. havent come in yet.
What you think, worth a try. ahahahaha
anywho..... no you cant revv your engine to 9600 RPM's without upgrading your valvetrain, and probably some other things. if you do, you run a VERY HIGH risk of freezing a valve, or bending one. stock cams wont make any power up in that range either, so dont bother
i have crower valves dual springs and stage 3 crower shafts. im trying something new here. you wont know if you try right? testing things out.... and youre not helping me by giving me lame remarks GraphiteMW lol
ok well you failed to mention that you had a crower valvetrain.....
H23 blocks are notorious for spinning bearings also, so i hope you installed the H22 oil squirters. even still i wouldnt revv really high.
guess i wont rev up that high then. =/ what a waste of mula. lol, you think 8200 is good enough? or still to high? yeah, ive always spend on something stupid. oh wells. do it just for fun.
well then sell that chip back on ebay to other some helpless soul and go to http://www.phearable.net to get a real basemap then have someone TUNE the ecu to your motor.
revving points are pointless without power, chipped ecus are pointless without a tune.
btw, your not trying anything new.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoiTypeR »</TD></TR><TR><TD CLASS="quote">i have crower valves dual springs and stage 3 crower shafts.
are the dual springs crower, and did you also upgrade the retainers too??? at least youre asking before you stick things in your car rather than just doing it and then wondering why things are messed up.....even with stage 1 cams, let alone stage 3, i wouldnt drive on those until tuned, if u have to, stay below 3k....also you may want to clay the motor, h23 increased stroke + stage 3 cams, there could be contact, theoretically youre valvetrain could still be producing power up to 9600, but dont try until a dyno has proven it so AND IS TUNED!!!! even if there is power up there, u do still run the risk of bearing failures, piston speeds with that stroke are higher than most h22/f20/b/d series which go up to 8-10k....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95greenlude »</TD></TR><TR><TD CLASS="quote">H23 blocks are notorious for spinning bearings also, so i hope you installed the H22 oil squirters. even still i wouldnt revv really high.</TD></TR></TABLE>
oil squirters squirt the cylinder walls and botom of the piston, even while dripping down the oil isnt going to do **** to help the rod/main bearings....plus i believe the h23/f22 rod journals and bearings have oil passages that send oil to the piston pin and out of the sides of the pistons, not positive on that though....
The oil squirters are use to cool the pistons... it will lube the walls but you dont need to worry about the cylinder walls, You need to worry about the bearings way before the walls. Still good for you to install them.
Chances are your motor will break before you get close to 9K RPM. Some random *** chipped ECU and 50mm mains are a huge set back for those high revs. Those cams wont even make power that high up anyway. If you wanna build a big, high rev motor, you have to take many things in to account and address many issues before they can become problems...I mean REALLY thinking outside the box and ultimately doing something new.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Televator »</TD></TR><TR><TD CLASS="quote">Chances are your motor will break before you get close to 9K RPM. Some random *** chipped ECU and 50mm mains are a huge set back for those high revs. Those cams wont even make power that high up anyway. If you wanna build a big, high rev motor, you have to take many things in to account and address many issues before they can become problems...I mean REALLY thinking outside the box and ultimately doing something new.</TD></TR></TABLE>
correct.
Im not a fan of the hybrid h23 vtecs.
I like my h22's 55mm Mains, good peace of mind.
correct.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hondalude »</TD></TR><TR><TD CLASS="quote">
correct.
I like my h22's 55mm Mains, good peace of mind.</TD></TR></TABLE>
That's the reason I jumped on the H23A instead of a regular H23A1.
correct.
That's the reason I jumped on the H23A instead of a regular H23A1. </TD></TR></TABLE>
yea im not gonna lie. the h23a is a beast
hard to find...
hard to find...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twistedbydezign »</TD></TR><TR><TD CLASS="quote">
oil squirters squirt the cylinder walls and botom of the piston, even while dripping down the oil isnt going to do **** to help the rod/main bearings....plus i believe the h23/f22 rod journals and bearings have oil passages that send oil to the piston pin and out of the sides of the pistons, not positive on that though....</TD></TR></TABLE>
on me
on me
1SIKZ06
Feb 17, 2009 06:36 PM
