Jdm H22 dizz cap
Old Feb 21, 2007 | 07:29 PM
93lxh22's Avatar
Default Jdm H22 dizz cap
i'm lookin for a msd modify cap but i can't seem to find one i been lookin everywhere. Ive heard that i can use the 00 civic si cap but don't know. so i need some help
Old Feb 22, 2007 | 02:52 PM
93lxh22's Avatar
Default Re: Jdm H22 dizz cap (93lxh22)
bump...
Old Feb 22, 2007 | 03:27 PM
ALLMOTORH22A's Avatar
are u trying to run an external coil?
Old Feb 22, 2007 | 04:43 PM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93lxh22 &raquo;</TD></TR><TR><TD CLASS="quote"> i'm lookin for a msd modify cap but i can't seem to find one i been lookin everywhere. Ive heard that i can use the 00 civic si cap but don't know. so i need some help</TD></TR></TABLE>
Just to let you know, your stock ignition is good for 350hp easily.
Old Feb 22, 2007 | 09:49 PM
93lxh22's Avatar
Default Re: Jdm H22 dizz cap (ALLMOTORH22A)
yea i want to change to external. i want to hook up my msd 6al
Old Feb 25, 2007 | 12:17 PM
u can use a usdm h22 dizzy cap.. or another b series msd cap i believe
Old Feb 25, 2007 | 01:30 PM
951dc5's Avatar
what? thought jdm h22a are the same as usdm. So usdm have external and jdm dont? that sucks. just when i'm about to swap a jdm over my dead usdm h22a1
Old Feb 25, 2007 | 02:26 PM
91SI92's Avatar
hey whats up. u can run a msd extreme cap along with the rotor wit a msd ss blaster coil. when u get the wires u gonna have to switch the ends on them that click onto the cap. i have the same set up but i'm using an h23 dizzy instead. got any question let me know.
Old Feb 26, 2007 | 12:23 PM
951dc5's Avatar
Default Re: Jdm H22 dizz cap (91SI92)
i have a question. Is the jdm h22a dizzy different from usdm? thanks
Old Feb 26, 2007 | 03:12 PM
91SI92's Avatar
Default Re: Jdm H22 dizz cap (Prelude951)
i don't believe so. the one that came wit my JDM motor is an internal coil. if u need any of the msd part numbers let me kno. i have extreme cap n rotor, msd wires wit adaptor cap end and ss blaster external coil. oh 1 other thing u might wanna change your ignitor in the distributor when u run that ss blastor. its burnt mine all up. it was black stained when i took it out.
Old Mar 1, 2007 | 02:57 PM
951dc5's Avatar
hey can i use my stock usdm h22a1 dizzy on a jdm h22a?
Old Mar 1, 2007 | 04:44 PM
snobordboy's Avatar
Moderator
prelude951, yes the usdm and jdm are different, usdm has external coil, jdm has internal, and if you use your usdm wire harness, you have no issue running the usdm dist and external coil. if you use the jdm harness, you do have to splice a few wires, which you can find the how to in the faq i think, or archived search for sure.
Old Mar 3, 2007 | 09:07 AM
951dc5's Avatar
Default Re: Jdm H22 dizz cap (snobordboi)
so i can pull my usdm dizz off and plug into the jdm and it should work ok without any timing issue?
Old Mar 3, 2007 | 06:30 PM
91SI92's Avatar
u learn somethin new eryday. i didn't kno they were different. thanks for clearin that up for me.
b16hybridsol
Jun 20, 2005 02:50 PM
vtec420kingH22
Jun 9, 2005 04:10 PM
dmxsoulja3
Mar 13, 2005 06:19 PM
dominate9
Aug 24, 2003 03:37 PM
