Positive impression of new formula Honda MTF
Old Feb 21, 2007 | 06:37 PM
mrmanuke's Avatar
Default Positive impression of new formula Honda MTF
I'm sure others have posted this plenty, but I just changed to the new Honda MTF and my initial impression is very good. I had a lot of 3rd gear grind in mid to high RPMs and a little 5th gear grind in high RPMs. So far I have not had any grinds since changing the fluid today. I will update if anything changes.
Old Feb 21, 2007 | 07:03 PM
vinuneuro's Avatar
Default Re: Positive impression of new formula Honda MTF (mrmanuke)
Cool. I plan of switching this spring. Regular honda mtf isn't very good at extreme cold temps.
Old Feb 21, 2007 | 07:06 PM
GraphiteMW's Avatar
Default Re: Positive impression of new formula Honda MTF (vinuneuro)
I get 3rd gear grinds after my car warms up. I should try it sometime.
Old Feb 21, 2007 | 07:14 PM
mrmanuke's Avatar
Yeah, that's another thing I can't test yet since it's not cold enough this week. My 2nd was grinding a little last week when it was near 0 degrees out.
Old Feb 21, 2007 | 07:51 PM
vinuneuro's Avatar
When it was <0 last week..2nd would grind just a little unless i double clutches.
Old Feb 21, 2007 | 08:08 PM
RA102725's Avatar
hmm.. is this available at honda dealers or just acura?? How much? and how can you make sure you get the "new" stuff?
Old Feb 21, 2007 | 08:16 PM
vinuneuro's Avatar
Default Re: (mikesta21)
Available at both. I remember someone saying that it's 5-6 a quart. There was a long thread about this not too too long ago. Search.
Honda: P/N 08798-9031
Acura: P/N 08798-9031A
Old Feb 21, 2007 | 10:12 PM
CGags13's Avatar
it replaced the "old stuff"...is got a white cap...m2b4 no likey hace frio...too bad it was 70 here today suckas!
Old Feb 21, 2007 | 10:18 PM
nonvteclude's Avatar
Default Re: (CGags13)
the new stuff works great , i had that 3rd gear grind and it was gone after about 5 miles of driving. it is like 750 a quart at the dealer but well worth it
Old Feb 22, 2007 | 03:25 AM
mrmanuke's Avatar
When I went to my Honda dealership they were actually selling the old stuff and the new stuff. The lady at the counter actually went to grab the old stuff and I had to specifically ask for the new. So watch out and don't accidentally buy the old stuff! And if you are having them change the fluid for you, I think they told me it would be around $55, but make sure to specifically ask for the new formula fluid. They charged me $6.69 for each bottle, but it was well worth it so far.
Old Feb 22, 2007 | 03:40 AM
DCxMagus's Avatar
Default Re: (mrmanuke)
yeah didn't the new stuff get a bit of synchromesh formula added to it? I'll look out for it when I change my clutch
Old Feb 22, 2007 | 05:08 AM
ilikehonda's Avatar
i have been running that stuff for a few years and have had no trouble with the old...worked fine for me but i must say i do like the new stuff.
also only use one qt of honda and use one quart of gm syncromesh....works wonders
Old Feb 22, 2007 | 05:12 AM
tacticalcustoms's Avatar
Default Re: (ilikehonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilikehonda &raquo;</TD></TR><TR><TD CLASS="quote">i have been running that stuff for a few years and have had no trouble with the old...worked fine for me but i must say i do like the new stuff.
also only use one qt of honda and use one quart of gm syncromesh....works wonders</TD></TR></TABLE>
I don't know about you but I'm gonna stick with something made by honda for honda's. Not some GM made crap.
Anyways the new stuff works wonders in the cold weather. The dealership I go to said they were required to send the old MTF back to the honda warehouse. So I dunno if other dealers were following that trend. just some insite.
Old Feb 22, 2007 | 05:33 AM
hu's Avatar
hu
Default Re: (tacticalcustoms)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tacticalcustoms &raquo;</TD></TR><TR><TD CLASS="quote">
For whatever reason, that GM crap works for a lot of people!
Old Feb 22, 2007 | 05:51 AM
Default Re: (hu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hu &raquo;</TD></TR><TR><TD CLASS="quote">
For whatever reason, that GM crap works for a lot of people!</TD></TR></TABLE>
it may work. but wouldn't you much rather use something designed for your vehicle then to use another companies brand..
GM syncro is designed for trannys that have a higher amount of trq. and friction. using a heavy oil like that in a honda tranny is most likely going to be prone to failure or dmg.
Old Feb 22, 2007 | 12:00 PM
rawNArsxS's Avatar
i bought mine about a month ago. i went to the honda dealer 1st n when i asked about the new stuff he said he wasnt sure wut they had so he opened up a new box. they were still gettin the old stuff. then he called the acura dealership down the road n asked them if they heard about it. they had it n told the honda guy about it, how much better it was yadda yadda yadda. the honda guy took all the info down n then they said they were gonna start ordering the new stuff right away.
Old Feb 22, 2007 | 04:13 PM
my9thtry's Avatar
the honda fluid is heavier bud iirc
Old Feb 28, 2007 | 02:54 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: (vinuneuro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">Available at both. I remember someone saying that it's 5-6 a quart. There was a long thread about this not too too long ago. Search.
Acura: P/N 08798-9031A </TD></TR></TABLE>
Anyone know what the part number is/was of the old Honda MTF so I can make sure I get the new stuff?
I went to the Honda dealer and gave them the part number listed above and they gave me a bottle with the same part number and the letter "c" at the end of it. They said they didn't know anything about the new version. (I'm also in Canada if that matters)
Old Feb 28, 2007 | 03:02 PM
rawNArsxS's Avatar
Default Re: (00Red_SiR)
did the one they offered have a white cap?
Old Feb 28, 2007 | 03:14 PM
Default Re: (rawNAprelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rawNAprelude &raquo;</TD></TR><TR><TD CLASS="quote">did the one they offered have a white cap?</TD></TR></TABLE>
with a green label
Old Feb 28, 2007 | 03:39 PM
00Red_SiR's Avatar
All Motor Mentor
no, the one I have is completely black with a black top on it. In Canada our oil comes in 1 litre bottles, not quarts and I think they possibly use different colors which is why I was wondering about the old fluids part number.
Old Feb 28, 2007 | 03:43 PM
rawNArsxS's Avatar
expletive if i know then...canada is weird
Old Feb 28, 2007 | 03:52 PM
00Red_SiR's Avatar
All Motor Mentor
haha, ya I know...the metric system..varying model designations between US and Canada even though they are the same cars...frustrating when it should be so easy.
As I was saying, if someone could find me the OLD part number for the original MTF in the US, I could compare it to the new one and see if there's a difference. I've been searching on here but can't find anything. Someone must have an old bottle kicking around in their garage somewhere. You do have 10 x the population we do...lol
Old Mar 1, 2007 | 05:28 PM
00Red_SiR's Avatar
All Motor Mentor
Here's some pics of what my bottles of MTF look like:
[IMG]
[/IMG]
Look familiar to anyone?
Old Mar 1, 2007 | 07:22 PM
93h22a1vtec's Avatar
Anyways the new stuff works wonders in the cold weather. The dealership I go to said they were required to send the old MTF back to the honda warehouse. So I dunno if other dealers were following that trend. just some insite.</TD></TR></TABLE>
Yea, GM "crap" is the ****. However now that honda came out with the MTF 2 that is sapposibly the same stuff im gonna use it in my fresh tranny. All the honda dealers tell me that they dont know anything about it, dont know if its the same or similar to GM and say its for 07 vehicles and up
