syptoms of a bad distributor
Old May 20, 2002 | 06:56 PM
Brian_92GSR's Avatar
New User
Default syptoms of a bad distributor
Can anyone give me some signs of a bad distributor? My problem is under WOT at times the check engine light flashes on for a second, and the car loses all power, as if it stalled but is still running. I'm pretty sure it just stopped firing for that second or two.
Old May 20, 2002 | 07:27 PM
BigBlockCRX's Avatar
New User
Default Re: syptoms of a bad distributor (Brian_92GSR)
check your ignitor
most likely it is that. take your cap off and check for a reddish/brownish colored 'dust' inside.. if that is present, then your distributor bearing is shot and you will have to get a new distributor chassis.
look at your coil and check the hole. if it looks whitish or crusty, it might be bad also, but an intermittant problem is most likely your ignitor (silver square box inside the distributor with 5 wires connected to it)
OH yeah, it could be your rotor too, it might have come loose or something like that
Old May 20, 2002 | 09:14 PM
91DA9's Avatar
Default Re: syptoms of a bad distributor (BigBlockCRX)
Would any of those fit in with it happening very rarely. I actually don't think it has anything to do with WOT, it just happens when I shift hard from first to second. I went over a speed bump a little too fast today and it happened. I'm starting to think it is happening due to being jolted around.
Old May 20, 2002 | 11:57 PM
kinesistech's Avatar
Default Re: syptoms of a bad distributor (94IntegraGSR-OVR)
Check all of your ground points. Dont forget the one on the thermostat housing. If its caused by jolting, somthing is loose. You can do the wiggle test. Actually part of fords diagnosis is to shake each plug until you find a fault. Sometimes battery grounds get loose.
Old May 21, 2002 | 03:52 PM
iwhichisme's Avatar
when your car keeps cutting off on you during use, and it is hard to start. It will eventually give out leaving you stranded. I know from experience
Old May 21, 2002 | 04:09 PM
t's Avatar
t
You are getting misfire codes when it flashes like that. Check your wires, spark plugs
Old May 21, 2002 | 04:46 PM
New User
Default Re: syptoms of a bad distributor (t)
Is mirfire the only code that goes away? It isn't possibile to check the code since it goes right away.
DRAGANDB1
Aug 9, 2018 06:19 PM
spooledex
Oct 10, 2009 12:36 AM
torreypjones
Feb 9, 2007 08:24 AM
trooper0641
Jul 9, 2005 12:22 PM
