12sec. NA coupe question!!!!
Well guys my goal was (is) to break 12s. 12.9 I'll be hapy...
I got a Em1 With a built ls/vtec making around 210whp-142Tq. I'll see tomorrow when I get it tunned.. I'm planing on running BFG 215- 225/50/15 the car is pretty much gutted, at Moroso it weights 2465lbs... I don't know if is accurate.
So straight to the point what does it takes to brake 12s on a 2465lbs car???
Set-ups, Timeslips, car Info will help thanks
Some good really 60's might get you there.
My GF's EJ8 weighed 2352 bone stock with some crap in the trunk, mostly full tank, spare, etc.
Is that weight with you in it?
Good Luck
I weighed my Si at moroso also.
I had:
No back seats
No passenger seat
No spare
Nothing in the trunk at all
Car came in at 2450 w/o me.
I'd go with some slicks and skip the Drag Radials if you really want 12's.
I had:
No back seats
No passenger seat
No spare
these things are usually close to accurate. it says 2450 lbs + 210 hp = 13.21 at 103mph. check it out
http://www.dragsource.com/inde...iew=5
220 hp gets u a 13.008 so lose some weight you fat bastard!
jk 135lbs = little guy. I=230 i need to drop the lbs.
well that's pretty light for all the stuff that you took out... I did the same thing Plus a full wire-tuck no Ac,Ps and all the crap on the engine bay... I still got some more stuff to take out like passenger seat, door panels, rear panels etc etc... But I'll do that when I comes to go to the track...
I just wanna know what does it takes to brake 12 on BFG
I'll always remember this guy at Moroso NHRA BFG NA class ran 12.9 ITR. I checked his car still had stock TB,IM,Injectors,DC4-1 header, full interior,b18c1... I was like OMG what the hell...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbh22 »</TD></TR><TR><TD CLASS="quote">these things are usually close to accurate. it says 2450 lbs + 210 hp = 13.21 at 103mph. check it out
jk 135lbs = little guy. I=230 i need to drop the lbs. </TD></TR></TABLE>
He said 210whp...your numbers are with 210 crank HP...not the same
jk 135lbs = little guy. I=230 i need to drop the lbs. </TD></TR></TABLE>He said 210whp...your numbers are with 210 crank HP...not the same
You'll be damned close to netting a 12 with BFGs if you've got a nice track and can get a good 60'. I don't wanna get your hopes up, but... go out and get the 12 that you most likely will.
p.s. If not... go get slicks. You will be.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA_JDM »</TD></TR><TR><TD CLASS="quote">
go to link read, see that it says wheel horsepower.people need to read and not be so fast to point out sonething wrong. (or their own stupidity) not trying to be a dick but pay a little attention to detail.
</TD></TR></TABLE>go to link read, see that it says wheel horsepower.people need to read and not be so fast to point out sonething wrong. (or their own stupidity) not trying to be a dick but pay a little attention to detail.
at 2350 on my crx(i weigh 250lbs), with 215whp/154 i ran 13.0. i was getting 1.9 60' times with a set of 14" bfg drag radial tires, wich were too big for my set up! good luck!
All motor '96-'00 coupes =
What does your powerband look like?
I ran 13.1 @ 104mph last March with 190whp in my coupe weighing in at 2560 lbs. with driver (I'm a heavyweight, breaking the scale at 230 lbs.
I also had a terrible launch that day, so it had another tenth or two in her.
I'll be trying once more for 12's, lauching at 7000 RPM instyead of 5500 RPM come March 24th.
You've posted a couple times in my build thread, haven't you?
- Derek
)I also had a terrible launch that day, so it had another tenth or two in her.
- Derek
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAlover »</TD></TR><TR><TD CLASS="quote">Well guys my goal was (is) to break 12s. 12.9 I'll be hapy...
I ran 12.82@109.8 with my DC2 making 238 Hub-HP/dynapack (~217 dynojet) and weighing 2450lbs with driver. That was with a 2.0 60ft on BFGs...
</TD></TR></TABLE>I ran 12.82@109.8 with my DC2 making 238 Hub-HP/dynapack (~217 dynojet) and weighing 2450lbs with driver. That was with a 2.0 60ft on BFGs...
Yes D-rob.
Well let's see what happends... If anything I'll get better cams and try to get more power out of the motor to achieve my goal
Ssaacckkeedd
Feb 4, 2007 05:37 AM
