97 Prelude SH... Low RPM Stalling
Old Feb 21, 2007 | 03:06 PM
djtrini's Avatar
Default 97 Prelude SH... Low RPM Stalling
Hey guys, I have a 97 Prelude SH.
This just happened the other day, I was driving at normal speeds on the hwy, exit on the offramp I needed. Came to a redlight, and the car just stalled. Went dead. I checked the oil it was down about 1.5 quarts. I always walk with extra oil. I put in a Quart of oil, and start the car again. It started with a very low idle, the oil light would flicker and the car would die.
I also detected a bit of a misfire at low RPM's 1500 or less. ANything above the car is running fine. Just at redlights or stop signs the car will just stall out.
Its got no check engine lights, no codes, no knocking.
I pulled the valve cover off today, everything in the head looks fine. Spark plugs Cylinder 1 and 4 were white brown, and 2 and 3 were BLACK.
My brother did a valve adjustment on the car, it has a little bit of a better idle. But that misfire is still there. higher rpm its fine, but its still stalling out.
Im a little stumped on the whole thing.
Any help or advice would be greatly appreciated.
Thanks
Travis
Old Feb 21, 2007 | 03:25 PM
TDCTyler's Avatar
Default Re: 97 Prelude SH... Low RPM Stalling (djtrini)
change your plugs. The problem could be alot of things, what have you replaced so far?
Old Feb 21, 2007 | 03:28 PM
Abandoned Ship's Avatar
New medicines
my car would misfire do to bad spark wires, so if it still does after you change the plugs have someone see if its them.
Old Feb 21, 2007 | 03:36 PM
djtrini's Avatar
NGK iridiums were just put in about 2000kms ago.
I also tried different spark plug wires with no change.
Cap and rotor are also fine.
No engine codes have occured as well.
Brand new O2 sensor installed roughly 4k ago.
Old Feb 21, 2007 | 03:43 PM
New medicines
Default Re: (djtrini)
sounds like youve got your stuff pretty covered. thats pretty much the extent of my engine technical knowledge.
good luck to you
Old Feb 21, 2007 | 03:53 PM
vinuneuro's Avatar
Fuel filter.
Old Feb 21, 2007 | 08:33 PM
AndrePerras's Avatar
Default Re: 97 Prelude SH... Low RPM Stalling (vinuneuro)
timing
Old Feb 21, 2007 | 09:55 PM
djtrini's Avatar
checked timing today its dead on the mark.
Fuel filter i'll check/change tomorrow
Old Feb 24, 2007 | 01:38 PM
jdmlude5
Guest
Posts: n/a
clean your throttle body.
Old Feb 24, 2007 | 07:54 PM
prelude_93vtec's Avatar
oil pressure?
Old Feb 25, 2007 | 09:14 PM
ShadowWeaver's Avatar
check ur grounds, clean iacv, fitv, then egr ports in that order if bogging doesnt subside...
shibbywhitedude
Jun 22, 2010 03:06 PM
whatan00b
Jul 8, 2009 06:18 AM
Catwink03
Jan 23, 2007 02:32 PM
