D16y7 block on 97 Civic Ex
Old Feb 21, 2007 | 02:04 PM
trboeclpse98's Avatar
Default D16y7 block on 97 Civic Ex
My friend hydrolocked his 97 Civic EX the other day driving through a flooded area, The car has a D16y8 engine in it right now and someone is selling a d16y7 short block, so i was wondering if everything from the D16y8 would transfer over to the D16y7 with no major modifications? I need an answer right away cuz i'm in the process of purchasing the engine.
Thanks.
Old Feb 21, 2007 | 02:39 PM
ifIexplode's Avatar
Yep it should drop right in, The only thing your gonna have to consider is The Cat on Y7 motors are Directly infront of the motor, right off the Exhuast manifold. and on the y8 the Cat is under the motor, So you will have to relocate an o2 sensor, And im sure the y8 ECU will run the motor, but probably not correctly, youll throw codes for Vtec.. ect..
Old Feb 21, 2007 | 03:00 PM
I'm only using the short block from a y7, the head, intake mani, and exhaust will be from the y8, kind of like a mini me swap.
Old Feb 21, 2007 | 03:10 PM
-JSpecEk*9-'s Avatar
Default Re: (trboeclpse98)
it will be fine jus throw the y7 block on and bolt everything bak together.
Justinrobi21
Mar 26, 2015 03:11 PM
spoonfedcrx
Jul 18, 2011 01:53 PM
progoon
Aug 4, 2006 06:02 PM
cevinklark
Dec 31, 2005 07:32 AM
