dpfi tb gasket change for hp gain?
I have searched to no avail
i want mpfi, but haven't the time, so...
i have a 91 dpfi std, can i change my tb gasket to the dx for an increase in hp?
need to mod/change ecu then?
thanks!!!!
thanks!!!!
There is a 22hp diff b/w the std and dx, and I heard it is mainly the tb gasket diff.
agreed, mpfi is the real answer, but not in the cards.
thanks again!
thanks again!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by budomove »</TD></TR><TR><TD CLASS="quote">There is a 22hp diff b/w the std and dx, and I heard it is mainly the tb gasket diff.
thanks again!
What you mean a difference of the STD, LX DX motor dual point are the same. Do you mean the HF as the STD?
thanks again!
</TD></TR></TABLE>What you mean a difference of the STD, LX DX motor dual point are the same. Do you mean the HF as the STD?
thanks again!
No sir, its in the cam.
thanks again!
</TD></TR></TABLE>No sir, its in the cam.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by budomove »</TD></TR><TR><TD CLASS="quote">i'll wait for mpfi
*pats on head*
it'll be well worth it.
</TD></TR></TABLE>*pats on head*
I dug a`little more, and the diff b/w the b1 and b2 is as follows:
cams
timing
tb restrictor plate b/w tb and im on b1
ecu
upper butterfly on b1 doesn't open all the way.
i'm waiting for mpfi
cams
timing
ecu
MisterMeanor
Mar 21, 2014 10:42 AM
skater5067
Apr 22, 2005 08:24 AM
