ls turbo problems with sputtering
ok let me see where should i begin. well i have a ek with 97 ls turbo running 10lbs internal is stock with 99-00 b16 tranny.
well before i put the turbo on i had problems with the iacv and the way how it idles. it was still the same but recently my car sputtered and it died out on me. i it blew a fuse in the engine bay fuse box. its the ecu fuse so i know its not mechanical problem but its a electrical problem. so i checked all my wires and then i saw a wire that got pinch in so i rewire that and secured it so it wouldnt be pinch in anymore. well so i thought i fix the problem but i took it for a test drive just a lil while ago and i was driving normal it was ok but when i hit 3500 it sputtered and jerked. i had the cel on while driving normal but when i hit 3500 the cel turned off and turned back on after 10 seconds or so. well right now i do not know what the hell is happening. so if anyone knows please help me out thanks
well i just checked the cel and its throwing a code 8 and code 14
code 8 is tdc sensor- i have no clue what it is
code 14 is iacv
code 14 is iacv
hey i have just change out the dizzy on my motor and the problem is still there. i dont know what else to do the code 8 is still there..anyone know what else to do
kewbee7
Jul 19, 2006 07:06 PM
