Show me pics of your painted headlights!
Old May 20, 2002 | 06:00 PM
ElectronBlueGSR's Avatar
Default Show me pics of your painted headlights!
Show me pics of your painted headlights... 96-98, 99-00 or whatever.
Oh and I'm about to do mine.. I have a set of stock 96-98 headlights. Do you guys think I should leave the amber or clear it out? I'm leaning towards clearing it out for the cleaner look but then I don't want to get pulled over.. I've seen 99-00s WITH the amber and it looks badass but I don't know if I can say the same for 96-98. Give me your opinions!
Old May 20, 2002 | 06:02 PM
SyndicateEH's Avatar
Default Re: Show me pics of your painted headlights! (ElectronBlueGSR)
No, I will not! . . . He will though
Old May 20, 2002 | 06:18 PM
SlowB16's Avatar
Default Re: Show me pics of your painted headlights! (SyndicateEG)
Old May 20, 2002 | 06:23 PM
mechanik's Avatar
Default Re: Show me pics of your painted headlights! (SlowB16)
Yeah...
Old May 20, 2002 | 07:24 PM
ACTEG's Avatar
Default Re: Show me pics of your painted headlights! (mechanik)
wow nice civic, is that legal to have the turn signal part blacked out like that? and what kind of paint did you use (brand and color?)
Yeah...
[Modified by ACTEG, 4:24 AM 5/21/2002]
[Modified by ACTEG, 4:26 AM 5/21/2002]
Old May 20, 2002 | 07:36 PM
Default Re: Show me pics of your painted headlights! (ACTEG)
They make spary tint. I think Pep Boys sells it or use to. . . My friend did his teg real lights way back in '97ish . . heh
Old May 20, 2002 | 08:17 PM
BrandonClaps's Avatar
New User
mine painted gunmetal ;D
Old May 20, 2002 | 08:21 PM
AllMotorITR's Avatar
New User
Default Re: Show me pics of your painted headlights! (VTEC CX)
that looks good...
hell yeah
Old May 20, 2002 | 08:34 PM
New User
Default Re: Show me pics of your painted headlights! (1 FAST R)
thank you ;]
Old May 20, 2002 | 09:07 PM
MurphDog74's Avatar
Default Re: Show me pics of your painted headlights! (BrandonClaps)
that looks real good
Old May 20, 2002 | 09:37 PM
GapxGuy's Avatar
Sushi Buffet Champion
Default Re: Show me pics of your painted headlights! (MurphDog74)
Old May 20, 2002 | 10:46 PM
JDM-FREAK's Avatar
Default Re: Show me pics of your painted headlights! (GapxGuy)
which part are you supposed to paint and not paint?...
can someone tell me, how to paint those lights?...
i can't affort CTR lights.. those cost way too much~~ help please~
Old May 20, 2002 | 10:51 PM
meemomark's Avatar
Default Re: Show me pics of your painted headlights! (takumi_79)
nice headlights!
Old May 21, 2002 | 04:40 AM
CivicSiRacer's Avatar
Default Re: Show me pics of your painted headlights! (meemomark)
Old May 21, 2002 | 07:15 AM
SPORT INJECTION's Avatar
Default Re: Show me pics of your painted headlights! (CivicSiRacer)
Wow..all those pics look sweet guys! I have to do that this summer.
Old May 21, 2002 | 07:32 AM
nfiedler3's Avatar
the headlights comes apart into three pieces...ive seen pics on here maybe someone will post them up....one is the headlight piece itself, then the chrome shiny looking frame that goes over this which is what you will color to your liking, then the plastic (i think) cover that goes on the outside
Old May 21, 2002 | 10:01 AM
CivicDXR's Avatar
Default Re: Show me pics of your painted headlights! (nfiedler3)
Old May 21, 2002 | 10:11 AM
weezerdotc0m's Avatar
Default Re: Show me pics of your painted headlights! (CivicDXR)
deng....your car is nice...much props!
Old May 21, 2002 | 06:22 PM
mechanik's Avatar
Ok ok. Mine is the first Red Si.
I took out the headlights. Preheated over to like 200 degrees i think. Put the headlamps in on a big pan with foil on the bottom. Keep in over for maybe 10 minutes (although every couple of minutes check and make sure nothing is getting cooked!!!! Trust me, you don't want to fry your headlamps hehe) Immediately after, use a screwdriver and pry the headlight apart. It's a bitch, but the heat should loosen it up some. There are some tabs that you have to work with.
Next i think there are 2 screws that hold the headlamp assembly to the plastic part with you actually paint. NOTICE THAT MY BLINKER REFLECTOR IS NOT BLACKED OUT! Some people clear it out, but i like it with the orange reflector there. The reflector pops right out. Now you should have the plastic outer piece all seperated. This is what you will paint. You DO NOT want to paint the inside middle where the light needs to reflect. If you do, i hear you will not be able to see Basically you just paint the frame.
Take a fine grit of sandpaper, and lightly sand the frame to be painted. This will allow the paint to stick much better. I than sprayed a nice smooth skinny layer of primer. After that dried, i got, if i'm not mistaken a color called "Flat Black" or something like that from PepBoys. I sprayed a nice skinny layer on. Waited about 30 minutes or so, and applied another layer to finish up the job. Do not overspray or make the coat of paint too thick. After twas all dried, I reassembled. Push the headlight cover back and reseal the headlamp by putting the assembly back in the over for just a short period. Remember, not hotter than 200 degrees. This will loosen the adhesive so you can reuse it. Then push it back on as far as you can. for an extra layer of protection against leakage, i used CLEAR silicon on top of the factory adhesive. Let dry. Reinstall.
I love the look. It looks HOT! Anyway, any questions email me kevin@civicstyles.com as i will lose track of this thread.
Old May 21, 2002 | 06:48 PM
RoaringTurtle's Avatar
New User
here is mine
Old May 21, 2002 | 07:40 PM
Default Re: Show me pics of your painted headlights! (RoaringTurtle)
WOW those are some nice pics. Anyone leave the orange reflector on their 96-98 lights?
CivicSiRacer- Hey I noticed you painted everything including the reflector part of the headlight whereas most people left it chrome. Does this in any way affect the headlights at night? It looks very nice but I don't want to compromise the sight at night.
Old May 21, 2002 | 08:03 PM
CivicDXR's Avatar
Someone on this board has, I'm actually putting mine back next week, its a different look, plus I'm sick of having cops harass me about it.... I'll post pics when its done...
[Modified by CivicDXR, 10:07 PM 5/21/2002]
Old May 21, 2002 | 09:46 PM
Andrea_Aunie's Avatar
New User
From: work in Tennessee and live in Georgia, from Tampa, Florida, USA
omg u guys have some niceass cars
Old May 22, 2002 | 04:29 AM
mechanik's Avatar
If I'm not mistaken, CivicSiRacer on clubsi.com did mention how he could not see after he painted all the reflecting inner parts. Good thing he has foglamps!
Old May 22, 2002 | 05:46 PM
Ah screw it then, I'll just leave it chrome...
I'm probably gonna paint mine sometime this week, I'll be sure to post pics after they're done.
