Quick question : Knuckles of a 90-93 integra RS will work on CRX HF w B16 right ?
it works but its off a little bit...just get an alignment
but if you have a b16 in your HF already you most likely already have different knuckles unless you are running custom axles.
Yes, they will work.
Or you can press ls wheel bearings into the HF hubs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ozrednsx »</TD></TR><TR><TD CLASS="quote">it works but its off a little bit...just get an alignment
but if you have a b16 in your HF already you most likely already have different knuckles unless you are running custom axles.</TD></TR></TABLE> yes i do have integra's already it's just that my bearings are shot both of them so i would rather buy this http://cgi.ebay.com/ebaymotors...95213 then taking the time to replace them
or
according to the seller the bearings are good... there shouldnt be any play with it if the knuckles are not mounted in the car right ?
or
Thats just frickin' stupid. What makes you think the bearing is good on that POS? Save yourself a lot of trouble, go get new bearings at napa for about 130.00 for both, take the knuckles and the bearings to a shop and have em pressed in. It'll probably cost you like 20 bucks......
Doing **** half assed like this is the reason why tuners have a bad rep. Our **** breaks 10 times before we fix it right
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bejita »</TD></TR><TR><TD CLASS="quote">Thats just frickin' stupid. What makes you think the bearing is good on that POS? Save yourself a lot of trouble, go get new bearings at napa for about 130.00 for both, take the knuckles and the bearings to a shop and have em pressed in. It'll probably cost you like 20 bucks......
</TD></TR></TABLE> HUmmm according to the seller the bearings are good. But i was thiking about the same thing... half *** job sux... been there done that...
barney_SI
12
Dec 15, 2009 11:29 AM
mikesrex
12
Sep 18, 2006 06:25 PM
coot_er
May 21, 2004 09:24 AM
