Suspension Noise
Old Feb 21, 2007 | 08:28 AM
preludetospeed's Avatar
Default Suspension Noise
Just wondering if anyone would know why my front struts clicks whenever I make a stop and accelerate. It happens once per strut, like if I take off both will click once and then be fine until I slow down and then they will click once again until I accelerate again. My guess is the bearing cap but i just wanted to make sure. I have a 2000 Prelude with 147,xxx base model. Thanks for any help
Old Feb 21, 2007 | 08:33 AM
Chuckles99SH's Avatar
Default Re: Suspension Noise (preludetospeed)
probably your axle or CV joint clicking and not your strut.
Old Feb 21, 2007 | 08:41 AM
Default Re: Suspension Noise (Chuckles99SH)
Hum, I have never heard an axle click when it’s going strait. But I don’t know everything (don’t tell anyone)
Old Feb 21, 2007 | 09:05 AM
roller3804's Avatar
Probably the bushings that sit on top of the spring. Mine wore out and they rest against the frame and it causes a click sound when u stop and go
Old Feb 21, 2007 | 11:18 AM
CAN97SH's Avatar
Resident Hoser #1
Community Builder
Community Influencer
I have a 97 SH and am experiencing the worst clunking noises coming from the front suspension. I'm assuming it's the isolators but cannot tell as every place I take it to says it's fine. Mechanically they are fine but expletive to they ever make the worst noises ever. Especially in the winter.
the best fix I found was ordering some koni yellow/GC suspension kit
Old Feb 21, 2007 | 01:36 PM
britishdude's Avatar
Just done mine, it was the front sway bar endlinks that were making a clunk noise on accelerating or stopping, the bushes just wear out, I also add our roads are really rough, my 97 lude has 91k miles. I also had them go on my wife's CR-V so they must be a part that consistantly wears, anyway replaced those end bar links and the popping noise has gone.
Old Feb 22, 2007 | 01:12 PM
Well looks like I have some places to start looking. It's a good thing that its going to be good weather this weekend.
Old Feb 22, 2007 | 01:27 PM
Easy check is to jack each wheel up in turn, get a pal to tug quickly on the wheel top and bottom while you shine a flashlight on the sway bar links. You will hear the clunking and may also be able to see the play in them, if they need replacing.
Old Feb 22, 2007 | 02:22 PM
Default Re: Suspension Noise (britishdude)
Yeah i know i used to work on cars for a living (not a good living) but i am just a little lazy since i dont have access to a lift anymore but i will check those things
Old Feb 22, 2007 | 04:48 PM
SKDRCR's Avatar
Jack, your car off of the ground about an inch and stick a prybar underneath
the tire and pry it up, litsen and feel for loose play, if there is, you probably
need ball joints or upper control arms.
Then shake it from side to side, if there is play there it's either the tie rods
or wheel bearing/s.
Is there excessive clicking when your turning?
Old Feb 22, 2007 | 06:59 PM
Default Re: Suspension Noise (SKDRCR)
There is no clicking when i turn and its shake side to side and looseness then its tire rods and top to bottom its wheel bearing right
Glock17
May 13, 2011 02:22 AM
jdm_h22
Nov 16, 2008 04:09 PM
TomFin
Suspension & Brakes
Mar 6, 2006 11:20 AM
rustycivic
Mar 7, 2003 09:55 AM
LegendLS95
Aug 12, 2001 06:16 PM
