Cam gears not lining up... need help!!!
Old Feb 20, 2007 | 09:16 PM
realis9's Avatar
Default Cam gears not lining up... need help!!!
I was tensioning my timing belt and noticed the cam gears do not line up. I used the coat hanger trick to tension the timing belt because I didn't have a spring. When the crank pulley is at TDC, the cam gears do not line up. Is this normal? Does this interfere with the timing? What should I do? Any help is greatly appreciated.
Modified by realis9 at 12:33 AM 2/21/2007
Old Feb 20, 2007 | 11:54 PM
realis9's Avatar
Default Re: Cam gears not lining up... need help!!! (realis9)
anyone? is that o.k?
Old Feb 21, 2007 | 05:59 AM
Natural Aspirations's Avatar
picture does not work
Old Feb 21, 2007 | 06:17 AM
D-Rob's Avatar
Default Re: (Natural Aspirations)
Has your head been milled any?
Also, fix the picture so we can help you better.
- Derek
Old Feb 21, 2007 | 06:23 AM
jmm96gsr's Avatar
Default Re: (D-Rob)
Is this an old belt? Take it off and try agian.
Old Feb 21, 2007 | 09:07 AM
realis9's Avatar
Default Re: (jmm96gsr)
it's a toda timing belt has about 15000 the most if that. Take of the entire timing belt? Should i remove the crank pulley?
Old Feb 21, 2007 | 09:17 AM
jmm96gsr's Avatar
Default Re: (realis9)
You don't have to to take the crank pulley off, but it would make it easier. Also, try to post a pic, so we can see how far off it is.
Old Feb 21, 2007 | 09:38 AM
realis9's Avatar
here is the pic.
http://www.we-todd-did-racing....acazs
Old Feb 21, 2007 | 09:42 AM
alterdcreations's Avatar
their are upside down
Old Feb 21, 2007 | 10:14 AM
Mike@K-Tuned's Avatar
Default Re: (alterdcreations)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alterdcreations &raquo;</TD></TR><TR><TD CLASS="quote">their are upside down</TD></TR></TABLE>
Yes they are. In that position I believe the #1 piston is at BDC (bottom dead center) Rotate the crank until the cam gears have moved 180 degrees from the position in your pic. Then you can make sure everything lines up properly.
Old Feb 21, 2007 | 11:29 AM
Default Re: (LSvtecMike)
I HOPE HE KNOWS THAT
Old Feb 21, 2007 | 11:51 AM
Golden Eagle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alterdcreations &raquo;</TD></TR><TR><TD CLASS="quote">I HOPE HE KNOWS THAT</TD></TR></TABLE>
me too
Old Feb 21, 2007 | 08:47 PM
realis9's Avatar
Default Re: (Golden Eagle)
could you please explain this too me step by step please?
Old Feb 21, 2007 | 08:49 PM
The crank turns twice for every one rotation of the cams, spin the crank another rotation and take another picture
Old Feb 21, 2007 | 08:51 PM
realis9's Avatar
I just notice that they were upside down, but in that pic that #1 piston is at TDC even though the cam gear are upside down because i put a long screw driver in the #1 piston to check the pistons and it at TDC.
realis9's Avatar
^ o.k i will do that
Old Feb 21, 2007 | 09:02 PM
realis9's Avatar
i rotated the crank a whole 360 degree to make the cam gear face the up position and it's still off just like the first pic. what is my next step.
Old Feb 21, 2007 | 09:18 PM
1 2 NV's Avatar
this is obviously someone with no knowledge of how a 4 stroke motor works. therefor i come to the conclusion he knows nothing about cam gears lining up.
years of experience
Old Feb 21, 2007 | 09:19 PM
realis9's Avatar
Default Re: (1 2 NV)
well that why i'm posting here to learn. Not to be criticize about my knowledge on engines. what do you suggest?
Old Feb 22, 2007 | 03:57 AM
1 2 NV's Avatar
like the other guy said, rotate the motor so the cam gears are facing up. triple check to make sure #1 piston is at TDC. then tighten T belt. rotate motor over a couple full revolutions to make sure your cam degree markers are at 12 o'clock and when they are piston #1 is at TDC.
on a side note if your cam gears are less than 1 full tooth off you will be fine. ive had a couple motors line up perfectly before and ive had a couple motors look "slanted" like yours.
on a side note of a side note, ditch that toda T belt. there have been plenty of threads about what POS they are, losing teeth and whatnot.
Old Feb 22, 2007 | 04:00 AM
jmm96gsr's Avatar
I would take the belt off and try to line the cam gears and the crank up. It looks like it's off by a tooth. I would get a new belt also. Maybe the belt is stretched??
Old Feb 22, 2007 | 09:32 AM
from what i understand the engine is at tdc with the cam gears facing down
Old Feb 22, 2007 | 10:14 AM
realis9's Avatar
^ yes now the cam gears are facing up and the crank is at TDC and it is still off like the previous pic.
Old Feb 22, 2007 | 10:32 AM
ATYPR's Avatar
take a new pic
jmm96gsr's Avatar
OK, let's quit f*cking around and line everthing back up and install a NEW T-belt.
