3in alluminum tight bends????
Try woolf aircraft they should have whatever you need for tight aluminum bends. Not only that but maybe you should look into this... Thermal Flex sells alot of uniquely bent silicone that can offer tighter radius then any pipe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted-EG6 »</TD></TR><TR><TD CLASS="quote">can any one point me in the right direction for a 3in alluminum tight bend for im FMIC im looking to make a back door style IC versus the conventional style IC
thanks</TD></TR></TABLE>
What do you mean by tight?
If you want REALLY tight, then the cast alum. elbows are the only way to get it. If you're looking for 1D stuff (3" CLR on 3" tubing), then you can find that at quite a few places.
*Boostwerks*
Welding / Fabrication
12
May 2, 2006 03:55 AM
