Different B20 motor for a B20v does it matter?
Old Feb 20, 2007 | 06:53 PM
The Si's Avatar
I know that
95.5-98 JDM B20B are 8.8:1 p3f compression pistons
Rated at 126hp
99-00 JDM B20B are 9.6:1 PHK compresion pistons
Rated at 146hp
97-98 USDM B20B are 8.8:1 p3f compression pistons
Rated at 126hp
99-00 USDM B20Z are 9.6:1 PHK compression pistons
Rated at 146hp
does it matter what b20 bottom block i get for my b20v conversion?
i know the year have different hp and cp. thx HT
Modified by ThaSi at 11:19 PM 2/20/2007
Old Feb 20, 2007 | 07:07 PM
The Si's Avatar
Default Re: Different B20 motor for a B20v does it matter? (ThaSi)
bump
Old Feb 20, 2007 | 07:17 PM
B20_ej1's Avatar
no it doesnt matter.
Old Feb 20, 2007 | 08:01 PM
doood's Avatar
been there done that
if you plan for internals later on it doesnt matter
Old Feb 20, 2007 | 08:21 PM
93eg2james's Avatar
Default Re: Different B20 motor for a B20v does it matter? (doood)
Well besides the obvious...
If you use one of the motors with the higher compression ratio then you will obviously have higher compression with the b20vtec setup, so yes it does matter IF you plan on keeping the bottom end completely stock.
However it is a good idea to get new rod bolts and get the rods shotpeened if you plan on keeping them. B20 dont take high rpms well for extended periods of time (8000k rpm+).
Old Feb 20, 2007 | 10:17 PM
The Si's Avatar
thx end thread
Old Jun 22, 2010 | 02:26 PM
COEHR's Avatar
srry for bring this old thread back but what would be the diff if i did just want to keep the b20 stock, im planning on doing a b20v and i was wondering what b20 spec would be good for daily driving and ect im playing on putting a b16a2 head with itr cams
Old Jun 22, 2010 | 03:27 PM
Deetz's Avatar
Crazy Honda Guy
The higher the compression, the more power you make....B20Z is great
Old Jun 22, 2010 | 03:55 PM
95EG2's Avatar
b20z are torquey i ran a 15.1 with stock motor, intake and exhaust
eccentrix
Mar 22, 2015 08:09 AM
felipe69
10
Apr 12, 2009 02:33 PM
tigueremalo
Apr 15, 2007 10:35 AM
Battle Cat
Apr 13, 2005 10:25 AM
NeedMOPower
May 3, 2002 11:33 AM
