how to remove drivers side fendar
Old Feb 20, 2007 | 06:24 PM
d4rksid3's Avatar
Default how to remove drivers side fendar?
I have two questions.
Does anybody know how to remove the driver’s side fender from a 91 Honda CRX SI?
And will the fender from a 88 and 89 fit a 91 Honda CRX SI? Thank you
Old Feb 20, 2007 | 07:31 PM
doublethink's Avatar
Default Re: how to remove drivers side fendar? (d4rksid3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d4rksid3 &raquo;</TD></TR><TR><TD CLASS="quote">I have two questions.
And will the fender from a 88 and 89 fit a 91 Honda CRX SI? Thank you </TD></TR></TABLE>
fenders are the same, you just have to swap over the thinner 90-91 molding AND the clips that hold on the coner light.
88-89 fenders use screws instead of clips to hold on the corner light, but you can just swap over the clips from your existing 90-91 fender.
Old Feb 20, 2007 | 07:35 PM
gen2fanatic's Avatar
Theres three bolts up top in the engine bay, a couple up front by the corner light (remove first) , two inbetween the fender and the door, one below the door. Im sure theres a few more, just look around the whole fender.
Use 10mm socket on all, might need an extension for the ones inbetween the fender and door, keep the door open!!
Good luck
Old Feb 20, 2007 | 11:10 PM
d4rksid3's Avatar
Thank you guys for your reply’s I appreciate the help. I will take your advice and see if I can get this fender from the junk yard tomorrow. if I can I will take pictures and document it. Thank you.
Old Feb 20, 2007 | 11:25 PM
d4rksid3's Avatar
just found this picture on how to do it
Old Feb 20, 2007 | 11:47 PM
JapJunkie's Avatar
c'mon maaan common sense.
JuneBugDrfter
Apr 5, 2010 09:55 PM
SoClose
Aug 25, 2005 04:53 PM
equalizir
Jun 23, 2003 10:09 AM
