torque specs?
Old Feb 20, 2007 | 04:15 PM
crxpwr1's Avatar
Default torque specs?
whats the torque specs for theses
Old Feb 20, 2007 | 04:17 PM
veritasaequatis's Avatar
Default Re: torque specs? (crxpwr1)
what the hell are they
Old Feb 20, 2007 | 04:19 PM
crxpwr1's Avatar
Default Re: torque specs? (veritasaequatis)
they hold down the cams
Old Feb 20, 2007 | 04:21 PM
Scotland:EF3's Avatar
cam caps. be very careful when you torque these down i broke one of my b16 caps because i overtorqued it, i had to buy a new one from the honda dealer for like 30-40 bucks. be careful
Old Feb 20, 2007 | 04:22 PM
oops thought you were referring to the long pieces sorry but be careful with those
Old Feb 20, 2007 | 06:16 PM
crxpwr1's Avatar
Default Re: (88EF9)
what is the torque specs ive looked and I think it only said 15 pds....that dont sound right
Old Feb 20, 2007 | 06:19 PM
Default Re: (crxpwr1)
thats prolly right
since its on something thats part of a rotating assembly i wouldnt go any tighter than that and if i recall its to retain them not hold them in , if thats the case then why would they need to be torqued down more
Old Feb 20, 2007 | 06:26 PM
crxpwr1's Avatar
Default Re: (veritasaequatis)
i was just making sure because I didnt want the cams to be spinning freely. Do you understanding what im saying?
Old Feb 20, 2007 | 06:28 PM
absolutely ,id be weary of that to
Old Feb 20, 2007 | 06:31 PM
jedb18's Avatar
If I recall it is 22 ft. lbs
Old Feb 20, 2007 | 06:35 PM
crxpwr1's Avatar
Default Re: (jedb18)
alright I will probably open up the head next week and double check every thing thanks
Old Feb 20, 2007 | 06:47 PM
crxpwr1's Avatar
CAMSHAFT COVER SPECS
13, 9, 5, 1, 3, 7, 11 (side of cam cover closest to intake)
14, 10, 6, 2, 4, 8, 12 (side of cam cover closest to exhaust)
Shown above is one cam cover, sequence is the same for intake and exhaust cam cover.
#1-10 20ft-lbs (240in-lbs) #11-14 7.2ft-lbs (86in-lbs) (94+ B18C specs)
#1-10 16ft-lbs (192in-lbs) #11-14 8ft-lbs (96in-lbs) (B16A specs)
**not sure what the specs are for non-VTEC motors, sorry**
Seat each camshaft by pushing it towards the dizzy side of cylinder head.
I have a b16 so its soppuse to only be at 16 and 8 for the others?
Old Feb 21, 2007 | 02:21 PM
crxpwr1's Avatar
Old Feb 21, 2007 | 02:29 PM
nihad's Avatar
check the 99 si civic torque specs at the auto parts. book
StraightCivic
Apr 27, 2006 11:09 PM
m00nr0ck Si
Jan 1, 2006 11:39 AM
GsRwHiTe
Mar 10, 2004 09:51 PM
Tropicana18T
Mar 6, 2004 09:18 AM
DOHCtorTHRUST
Nov 8, 2002 07:43 AM
