Radiator swap...?
Old Feb 20, 2007 | 02:07 PM
sasinorm01's Avatar
Default Radiator swap...?
my ef sedan has a long radiator and when i test fit the turbo (t3/4) it touches the radiator....what other radiator could i use and will it effect the engine when i change it ......pics of actual setups would be great to thanks!
Old Feb 20, 2007 | 02:36 PM
MagnaniEG6's Avatar
Default Re: Radiator swap...? (sasinorm01)
this has been cover some many times. You could use an EG raditor and make some custom tabs to mount them
Old Feb 20, 2007 | 03:25 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: Radiator swap...? (MagnaniEG6)
or you could use a 94 dodge neon radiator that acually fits the stock ef mount points and is a half radiator.
there is some specification on the radiator, i.e. non ac, or non power steering or something to that effect for the neon half radiator that actually fits, other neon radiators dont work.. do a search for neon radiator and youll find the right info.
you need a wicked gangster lean to get the eg radiator to fit.
Old Feb 21, 2007 | 07:16 PM
sasinorm01's Avatar
but the ef sedan has too fans ...which one do i need to keep
RMXmitch
12
Nov 18, 2013 08:34 PM
EF9_RIDER37
Apr 3, 2010 08:57 PM
SInical
Apr 29, 2005 03:30 AM
D-Man
Jan 19, 2002 07:26 PM
