1993 accord se..... abs light
whats up world well i just purchased a 1993 accord se automatic for my daily driver.... my abs light is on and i cant figure it out.... i just swaped out the abs computer(trunk right side) with another one but the light came back on .... could it be the abs unit thats bad????? please help thanks!!!!!
On your car you can use the service check connector to get a 'flash' code on the ABS light link below;
http://members.troublecodes.ne...n.jpg
The light will flash a 2 part code main and sub-system; such as a long single is 1 and then 2 quick flashes is a code 1-2.
Have you checked the fluid level of the ABS unit and looked around for seeps and leaks?
Im pretty sure since its obd 1, it wont tell you specificaly whats wrong with the abs. anyway my abs doesnt work, its one of the wheel sensors. it stopped working one day then 3 months later it magicaly started working again, but it was flakey so I pulled the relay to manualy disable it.
newhondaowner29
Jan 11, 2006 08:11 PM
