Skunk2 Pro 1's???
Old Feb 20, 2007 | 11:45 AM
.I.Need.Money.'s Avatar
Default Skunk2 Pro 1's???
I'm putting P30 pistons in my GSR motor, and now I want to replace my ITR cams.
Would the Skunk2 Pro 1's be a good choice? It's daily driven so I don't want anything to crazy.
I already have portflow springs and retainers.
Anyone?
Old Feb 20, 2007 | 04:41 PM
92TypeR's Avatar
FSAE
Default Re: Skunk2 Pro 1's??? (93EGB18C1)
Skunk2 Pro-1 cams are great for 1.8L applications.
Also look into RM M22X cams.
Old Feb 20, 2007 | 07:56 PM
RaceCarRyne's Avatar
Default Re: Skunk2 Pro 1's??? (92TypeR)
yes pro 1
Old Feb 20, 2007 | 08:11 PM
SkoundrelUSA's Avatar
cute little bastard
They are a good choice
I love the rumble of my Pro 1s.
Old Feb 20, 2007 | 09:28 PM
Default Re: Skunk2 Pro 1's??? (SkoundrelUSA)
yes mine rumble also.. it helps that my vtec is locked in tho
Old Feb 21, 2007 | 11:05 AM
Default Re: Skunk2 Pro 1's??? (DC2jdmIntegra)
Are the cam profiles on the Blox type B the same as the S2 Pro 1???
Old Feb 21, 2007 | 05:37 PM
92TypeR's Avatar
FSAE
No. The Blox B camshafts are very similar to Skunk2 Stage 2's
Mild primaries, decent VTEC lobe.
Old Feb 23, 2007 | 08:48 PM
What's the difference between the Tuner Type B's and the Competition Type B's???
Old Feb 23, 2007 | 09:06 PM
oldskool teggy's Avatar
different primaries
Old Feb 23, 2007 | 09:33 PM
Default Re: Skunk2 Pro 1's??? (oldskool teggy)
How would the competition be for DD?
Old Feb 24, 2007 | 12:09 AM
teri_vti's Avatar
so which one is more agrresive? skunk 2 stage 2 (blox b) or skunk 2 pro1??
Old Feb 24, 2007 | 12:21 AM
92TypeR's Avatar
FSAE
Default Re: (teri_vti)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teri_vti &raquo;</TD></TR><TR><TD CLASS="quote">so which one is more agrresive? skunk 2 stage 2 (blox b) or skunk 2 pro1??</TD></TR></TABLE>
Nearly identical peak power numbers, Pro-1's will have more tq/hp in low/mid revvs.
Old Feb 24, 2007 | 07:40 AM
teri_vti's Avatar
aha, at racing they will be the same....though at daily drivin pro1s will make the car faster?
Old Feb 24, 2007 | 07:58 AM
Natural Aspirations's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oldskool teggy &raquo;</TD></TR><TR><TD CLASS="quote">different primaries</TD></TR></TABLE>
Different primary width, same lift and duration. Prety much a No No on used rockers.
Old Feb 24, 2007 | 08:44 AM
L_K's Avatar
L_K
Default Re: Skunk2 Pro 1's??? (Natural Aspirations)
for those of you who have the pro 1, wat compression are u guys running?
Old Feb 24, 2007 | 08:52 AM
Default Re: Skunk2 Pro 1's??? (L_K)
I have seen 9.8:1 to 13:1. Compression is not the most important thing in a motor and has been proved time and time again. With an increase in compression you are also going to see an increase in wear.
Old Feb 24, 2007 | 09:57 AM
pr0honda's Avatar
skunk2 pro1's will be a good choice as long as you have ability to tune your car. these cams i think are great for the street cause you have a pretty consistant powerband and low end power. they just require a little more tuning and make sure you degree them.
shawn
Old Feb 24, 2007 | 04:10 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Natural Aspirations &raquo;</TD></TR><TR><TD CLASS="quote">
Different primary width, same lift and duration. Prety much a No No on used rockers.</TD></TR></TABLE>
if it's the same lift and duration, how does it hurt rockers? they are just wider
Old Feb 24, 2007 | 07:46 PM
Rockers get worn during normal use stick a wider lobe in there and funny things happen.
Old Feb 24, 2007 | 07:52 PM
Default Re: (Natural Aspirations)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Natural Aspirations &raquo;</TD></TR><TR><TD CLASS="quote">Rockers get worn during normal use stick a wider lobe in there and funny things happen.</TD></TR></TABLE>
Like what?
Old Feb 24, 2007 | 08:14 PM
Very Bad Things
Old Feb 26, 2007 | 01:58 AM
sounds like a movie
Old Feb 26, 2007 | 06:08 AM
Hybrid96EK's Avatar
I have never had a problem with any aftermarket cams on "used" cam followers. Interesting that you say "bad things" will happen.
What would be the point of making a wider lobe? Sounds like a load of BS to me. The lobe can only be so wide since you only have so much room to work with and the contact path of the follower is only so wide. There would be no logical benefit from making a lobe wider.
Old Feb 26, 2007 | 07:04 AM
Default Re: (Hybrid93Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">
I have never had a problem with any aftermarket cams on "used" cam followers. Interesting that you say "bad things" will happen.</TD></TR></TABLE>
That is because everyone else makes their cams the same as Honda
Notice all 3 lobes have the same width?
What do you think will happen to a rocker than has a wear pattern of a narrower lobe. It going to put a lot of stress on the outer edge where the rocker is not worn.
What would be the point of making a wider lobe? Sounds like a load of BS to me. The lobe can only be so wide since you only have so much room to work with and the contact path of the follower is only so wide. There would be no logical benefit from making a lobe wider.</TD></TR></TABLE>
I agree there is no need for this. But as you can see from the picture BLOX has done it. I guess they have created something after all.
Old Feb 26, 2007 | 08:10 AM
Rollo Lawson's Avatar
Default Re: (93EGB18C1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93EGB18C1 &raquo;</TD></TR><TR><TD CLASS="quote">Like what?</TD></TR></TABLE>
i'm starting to believe he doesn't even know. all i know is my Jun3's & S2P1s have wider lobes than my BC3+'s. i have no rocker problems or abnormal wear with my P1's. they've been in for over a year.
Modified by B16C1 at 12:31 PM 2/26/2007
