Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
SCCA Roll Cage
Old Feb 20, 2007 | 11:03 AM
envee's Avatar
Default SCCA Roll Cage
Does anyone know what "bolt in" roll cages are accepted by the scca. Pre-fabbed cages. Thanks.
Old Feb 20, 2007 | 01:12 PM
Yellow Dragon's Avatar
Default Re: SCCA Roll Cage (envee)
Which SCCA class are you referring to?
Old Feb 20, 2007 | 08:15 PM
envee's Avatar
Default Re: SCCA Roll Cage (Yellow Dragon)
Im looking at solo, but i also was to do track racing. but that can come later.
Old Feb 22, 2007 | 12:53 PM
envee's Avatar
anyone?
Old Feb 22, 2007 | 01:51 PM
mc-integra111's Avatar
I don't know who makes these bolt in cages, but I believe they are only allowed on showroom stock and improved touring race cars. Do a web search for bolt in cages for showroom or IT racing classes or cars.
Old Feb 22, 2007 | 01:59 PM
envee's Avatar
Default Re: SCCA Roll Cage (mc-integra111)
i wasn't ness. refering to cages that actually bolt to the floor. i was refering to pre fabbed cages that are form fitted to applications, as opposed to custom cages.
Old Feb 22, 2007 | 03:10 PM
oh. In that case try Autopower. They should have a kit for anything. The kit will likely require some sort of customization with the new SCCA rules about door bars, but nothing complicated. My cage started from an Autopower kit, albeit with quite a bit of customization.
Old Feb 22, 2007 | 04:36 PM
envee's Avatar
what kind of customization?
Old Feb 22, 2007 | 06:16 PM
Solo1B16Hatch's Avatar
Kirk Racing
They are located in Birmingham, AL
Old Feb 22, 2007 | 06:41 PM
envee's Avatar
Default Re: SCCA Roll Cage (Solo1B16Hatch)
thats a roll bar. i need a cage.
Old Feb 22, 2007 | 06:43 PM
davidnyc's Avatar
http://kirkracing.com/bolt-in_roll_cage.htm
1. What kind of car is it?
2. Is it still street driven?
Old Feb 23, 2007 | 01:02 PM
Weston's Avatar
I'd suggest a roll <u>bar</u>, if anything at all. If you get the autopower "race" rollbar, you can get a kit to turn it into a full cage at a later time. You don't want a roll cage in a street car because:
1) You will hit your bare head on it. That really really hurts when you just do it on accident, and it's a pretty serious injury when you do it in a wreck. I have the expensive SFI-rated padding on mine and that helps a lot (It no longer hurts when I bump my bare head on it), but it still would not be "fun" in an accident without a helmet on, and I promise you that constantly bumping into it gets old real fast. While a custom welded cage can give you another inch or two in some places, it will still be close, and some spots just don't have any more room to work with.
2) Climbing over double door bars is usually a pain in the ***. Single bars are just an annoyance, but neither SCCA nor NASA allows single bars on the driver's side anymore. A removable steering wheel will help, but it's still not something you want to be doing daily. The amount of room you have to work with varies between different types of cars (ie my Porsche is a lot tighter than my Integra), but the bottom line is that it's not going to be much different than climbing out through your window.
3) You will lose your interior. Yes, Autopower cages are meant to accomodate most interiors, sometimes with minor trimming, but in reality, it's easier and more practical to just strip the interior than to try to figure out a way to keep it. At the very least, you'll lose your sun visors, have to hack up your door panels, and chop holes in your carpeting. You might as well just gut the thing to make life simpler and try to counteract some of the weight of the cage.
4) A cage is added weight, and a bolt-in cage does not improve chasis stiffness enough to really matter. Cages are most often attached to sheet metal, not the frame. So there's no real performance advantage, only the disavantage of weight.
5) Without knowing what class you want to be road racing in yet, you should hold off on getting the cage. Different classes have different rules. Gutting your interior and installing a cage is also likely to screw up your autocross classing.
Modified by Weston at 3:12 PM 2/23/2007
Old Feb 23, 2007 | 03:17 PM
envee's Avatar
Default Re: SCCA Roll Cage (davidnyc)
1. 93 dx hatch.
2. Yes.
Old Feb 23, 2007 | 05:40 PM
davidnyc's Avatar
Some advice:
Buy a rollbar... learn how to drive at speed on the track.... save your $$$ and then buy a car, do not build.
Granted, I love building (because it never ends) my Honda Challenge ITR, but, it would of been wiser to just buy an ITS GSR or ITA LS.
Old Feb 24, 2007 | 05:44 PM
envee's Avatar
I already have experience. I've gone to schools, some open events, i've had drivers ride with me. now i want to put it to use.
Old Feb 25, 2007 | 05:17 PM
JOE BD-0's Avatar
SCCA rules are soon to change to "weld in" for wheel to wheel racing.......good luck
Old Feb 25, 2007 | 06:19 PM
envee's Avatar
Default Re: SCCA Roll Cage (JOE BD-0)
ugh, looks like nasa is the way to go :D
Old Mar 4, 2007 | 01:40 PM
Weston's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JOE BD-0 &raquo;</TD></TR><TR><TD CLASS="quote">SCCA rules are soon to change to "weld in" for wheel to wheel racing.......good luck</TD></TR></TABLE>
All classes? What's the source on this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by envee &raquo;</TD></TR><TR><TD CLASS="quote">ugh, looks like nasa is the way to go :D</TD></TR></TABLE>
That's what most people who have tried it say.
Old Mar 4, 2007 | 01:46 PM
slammed_93_hatch's Avatar
nasa will fallow suit shortly after.
has to do with a bunch of legality stuff.
Old Mar 4, 2007 | 05:14 PM
granracing's Avatar
envee,
Until that is added in their rule book (if?), don't make your decision on where you'll be racing based on this speculation. You may still find that buying a pre-fabbed cage and having it welded in is the best option anyways.
Old Mar 4, 2007 | 05:28 PM
Chris F's Avatar
Default Re: (granracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by granracing &raquo;</TD></TR><TR><TD CLASS="quote">You may still find that buying an already-built car with a nice professionally built cage is the best option anyways.</TD></TR></TABLE>
Fixed for ya
Old Mar 5, 2007 | 03:28 AM
granracing's Avatar
Agreed.
Old Mar 6, 2007 | 10:43 AM
Weston's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by granracing &raquo;</TD></TR><TR><TD CLASS="quote">envee,
Until that is added in their rule book (if?), don't make your decision on where you'll be racing based on this speculation. You may still find that buying a pre-fabbed cage and having it welded in is the best option anyways.</TD></TR></TABLE>
Yup, I haven't heard anything more than rumors about this happening.
Bolt-in cages do have their disadvantages, but it sure is a nice cheap way to get started (we all know there are plenty of other expenses involved, especially with HANS).
poison
Jul 11, 2006 04:40 PM
Power Rev Racing
73
Oct 19, 2005 05:39 AM
Hockey27925
Oct 5, 2005 06:45 PM
Tyson
Oct 20, 2002 07:51 PM
D15B_Turbo
Aug 29, 2002 10:36 AM
