turn signal doesnt go off by itself?
Old Feb 20, 2007 | 09:44 AM
russianswty's Avatar
Default turn signal doesnt go off by itself?
Ok so here's the situation when you turn on the turn signal and turn
the turn signal should stop on its own, but it doesnt I have to do it manually,
Now I do have one of those after market wheels on there.
So im guessing would it have something to do with the fact that my wheel
isnt stock,
Or would it be the switch its self?
Old Feb 20, 2007 | 01:36 PM
Perfectionist's Avatar
Default Re: turn signal doesnt go off by itself? (russianswty)
There is a ring in the column that is supposed to catch and cancell the signal. Either yours was removed to mount the aftermarket wheel, or the 'tang' is broken. Does it fail to cancell both left and right signals?
Old Feb 20, 2007 | 08:56 PM
Default Re: turn signal doesnt go off by itself? (Perfectionist)
yeah it fails to cancels both ways. it has an after market hub and steering wheel on there
Old Feb 21, 2007 | 08:22 AM
JimBlake's Avatar
Can you get your hands on a factory steering wheel? Look on the backside of it's hub for a little lever that trips the mechanism to cancel the signal. Try to fabricate something similar on your steeringwheel hub.
Old Mar 5, 2007 | 09:07 AM
Default Re: turn signal doesnt go off by itself? (JimBlake)
does any body have a pic of a stock steering from the back? or
has anyone recreated the turn signal cut off switch
or is there a company that makes the steering wheel hubs make one
with that already?
Old Mar 5, 2007 | 10:27 AM
JimBlake's Avatar
I looked at parts drawings (hondaautomotiveparts.com) but it doesn't show enough detail to see what's needed. Besides, it might be different depending on what year is your car??
Look for a couple little levers coming from the turn-signal switch assembly. The steering wheel needs a tab that bumps against those levers.
see vick
12
Mar 5, 2021 05:49 AM
accordianex
Nov 14, 2006 02:27 AM
egvtec
18
Nov 11, 2005 03:35 PM
1hotintegra
Feb 23, 2003 06:17 PM
citanest
Jan 3, 2002 09:44 AM
