Balance belt tension adjustment without cover off
Old Feb 19, 2007 | 11:04 PM
chibiko's Avatar
Default Balance belt tension adjustment without cover off
when do this, why it is said to rotate the crankshaft 3-teeth on the camshaft sprocket. what will happen if more teeth are rotated, overtighten?
the tensioner apply tension to both the balance belt and timing belt, so if i did this, it will also change the tension for the timing belt?
HyperFlow
Aug 2, 2010 01:46 PM
civic=goodgasmileage
Honda Civic (2001 - 2005)
Oct 11, 2008 09:17 AM
MassCivicMan987
Jul 3, 2006 04:25 PM
crx_88_si
Jun 30, 2005 09:02 AM
VTHokie
Jul 23, 2002 07:47 AM
