whats wrong with this?
Old Feb 19, 2007 | 06:58 PM
gsr x civic's Avatar
Default whats wrong with this?
okay. well i recently got my motor tuned at my local shop . . .
i have a full bolt on gsr, minus the cat (stock), vafc, p28 chipped ecu, and it's in an ej1. motor has roughly 75k on it, and it's been maintained well (oil changes, spark plug replacement, etc)
so before the tune it was 128 whp 99 tq, and now its 146 whp 110 tq.
what the hell is up with this? full bolt on gsr only making barely 150whp?
oh and btw my camseal is fucked. could this be the problem?
help!
Old Feb 19, 2007 | 07:06 PM
b19coupe's Avatar
Default Re: whats wrong with this? (gsr x civic)
Stock cams?
Old Feb 19, 2007 | 07:07 PM
b16nonoy's Avatar
if its stock cams..that would be reasonable..
Old Feb 19, 2007 | 07:08 PM
yes. stock cams.
am i just being dumb?
edit :
i was wondering because my friend has the same motor in his 99 ex, but he's also replaced things like pulleys, timing belt, and other things i dont remember. he also has just an exhaust and is making 150whp untuned.
Old Feb 19, 2007 | 07:10 PM
ChickenH's Avatar
sounds about right.
Old Feb 19, 2007 | 07:14 PM
b19coupe's Avatar
Default Re: (gsr x civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr x civic &raquo;</TD></TR><TR><TD CLASS="quote">yes. stock cams.
There is your answer. 146 is about right. I have a fully built 2 liter that makes over 240 whp with Skunk Pro 2's. With stock B16 cams it only makes 190 or so.
would a bad camseal have any part in slight power loss? and i'm throwing a CEL also, probably from my o2 sensor because i just popped in a new header.
Old Feb 19, 2007 | 07:22 PM
NJIN BUILDR's Avatar
Camseal isn't it ,but the cel isn't helping.
Old Feb 19, 2007 | 07:23 PM
VTECJUN's Avatar
If you are throwing any check engine lights that should be the first thing that you fix. Your car is telling you something. The cam seal will not cause a power loss, just a mess.
Old Feb 19, 2007 | 07:29 PM
well i'm ignorant and i dont know how to use jumper pins to check my cel. i know you just connect it to 1&3 or something, and wait for it to flash, but idk. i'm ******* stupid
Old Feb 19, 2007 | 07:55 PM
VTECJUN's Avatar
Search "check CEL"
Old Feb 19, 2007 | 07:56 PM
Default Re: (VTECJUN)
http://check-engine-light-code....html
well i've been looking at that for like a month and a half now. idk wtf i can use for "jumper pins" and i haven't checked for my diagnostic pins. i dont recall seeing them ever.
Old Feb 19, 2007 | 08:00 PM
VTECJUN's Avatar
Use a piece of wire and strip the ends to make a U shape. Use that to stick in the plug. Turn the ignition on and watch the light blink. Long blinks are 10 and shorts are 1. It cycles over and over.
Old Feb 19, 2007 | 08:04 PM
any kind of wire? like speaker wires?
Old Feb 19, 2007 | 08:12 PM
H9Omega's Avatar
yeah any wire will do, its easy *** heck.
Old Feb 19, 2007 | 08:15 PM
doood's Avatar
been there done that
sounds like you had your expectations set too high. i'd be ecstatic if my bolt on's b18c1 made 150whp.
Old Feb 19, 2007 | 08:50 PM
thanks guys!
appreciate the help!
Old Feb 20, 2007 | 08:15 AM
89crxhf's Avatar
Default Re: whats wrong with this? (doood)
150 whp on a b18c1 is really low to me , my stock 1st gen b16 put down 153 to the wheels with only bolt ons, some thing else is wrong with your motor
Old Feb 20, 2007 | 08:39 AM
hm. i do have a dirty air filter, and i think i only have a cat back exhaust . i can't even remember. i have a greddy 4-2-1 header and a s2 intake mani, along with a akimoto (pretty much generic) intake and a 5zigen exhaust
Old Feb 20, 2007 | 10:54 AM
A.E Motoring's Avatar
try doing a compression test, see if the motor is healthy, i put down 160 in a stock gsr untuned, with only a skunk intake mani, stock header, stock intake
Old Feb 20, 2007 | 12:31 PM
hondacivicsi92's Avatar
172 is flywheel hp so sounds right
Old Feb 20, 2007 | 12:44 PM
well what can i use to test my compression? i dont have a tester, so i'm SOL at that point!
any advice on how to check it without using a tester?
Old Feb 20, 2007 | 12:57 PM
H9Omega's Avatar
you cant really check it without a tester, the numbers seem extremely low. at a local dyno stock b16s put out that much, (1st gen b16s) and i havent seen a stock gsr dyno tune, but one with a skunk2 mani,aem intake, cheap dc header and and apexi ws catback put out 168whp on a dynojet.
Old Feb 20, 2007 | 01:06 PM
96Spec Ek's Avatar
What kind of dyno is this on?
Old Feb 20, 2007 | 03:36 PM
DynoJet Research . . .
CF: SAE SMOOTHING: 5
Run Conditions 70.24 F, 29.79 in-Hg, Humidity 14%, SAE .97
Max Power 146.51
Max Torque 110.91
