putting motor back together...one problem
Old Feb 19, 2007 | 06:43 PM
teg01type-r's Avatar
Default putting motor back together...one problem
ive finished putting my motor back together and i cant get this one clip to stay, its the green one right next to the distributer, does anyone know what that does??? and has anyone had this problem before, ive check around and theres no reason that it shouldnt but i dont know...Thanks in advance...
Old Feb 19, 2007 | 06:46 PM
LunchboxZT's Avatar
Default Re: putting motor back together...one problem (teg01type-r)
Green clip by the distrib... You mean a wire connection? Can you post a picture of which one your talking about? If it's the one I'm thinking of I believe it's related to the Vtak solenoid. and without it your vtak wouldn't pop.
Old Feb 19, 2007 | 08:44 PM
Default Re: putting motor back together...one problem (LunchboxZT)
[IMG][/IMG]
Old Feb 19, 2007 | 08:46 PM
its right under the distributer cap, also when i was looking at my tranny when i got it back it looks like they forgot to but my tranny vent cap back on... do you know if i can drive around with that off??? and would acura have them...
Old Feb 19, 2007 | 08:53 PM
itralex's Avatar
it looks like your VTEC Solenoid plug.
check to see if the male or female end of the plug is broken
Old Feb 20, 2007 | 07:31 AM
Default Re: putting motor back together...one problem (itralex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itralex &raquo;</TD></TR><TR><TD CLASS="quote">it looks like your VTEC Solenoid plug.
check to see if the male or female end of the plug is broken</TD></TR></TABLE>
what if that plug is broken, how big of a hassle is it to replce it??? thanks.
Old Feb 20, 2007 | 07:40 AM
chad's Avatar
Moderator
that green plug does not pllug into the head under the dizzy....it plugs into the green plug in front of the dizzy....
Old Feb 20, 2007 | 07:49 AM
Default Re: putting motor back together...one problem (chad)
i know that, it plugs into the Green connector, thats not the issue i know where it goes it just wont plug in for somereason, it will go on but it wont clip, and ive looked and nothing is blocking it.
Old Feb 20, 2007 | 08:02 AM
LunchboxZT's Avatar
Sounds like it's time for Duct Tape! plug it in and hold it there, start the car up and see if you throw a CEL. There is a specific one for that plug failing (I forget which one it was)
Modified by LunchboxZT at 9:13 AM 2/20/2007
Old Feb 20, 2007 | 08:29 AM
thanks man, hopefully i can figure out why its not holding..
Old Feb 20, 2007 | 08:45 AM
Dave_B's Avatar
HondaBond FTW!!!!
Old Feb 20, 2007 | 09:27 AM
Default Re: (Dave_B)
yea i figured out its actually the oil pressure switch. But im going to go home and see if i can figure it out, is there anyway to take it out, like unscrew it to see whats really going on under there cuz its kinda hard to get my head down there to see, Thanks.
Old Feb 20, 2007 | 09:31 AM
LunchboxZT's Avatar
Default Re: (teg01type-r)
Are you sure we're thinking of the same plug? The Green plug for the VTEC solinoid oil pressure should be extremely accessable and in plain view, you should be able to (if memory serves me) get to those plugs with no problems.. Did you check and see if the snap that holds it is damaged? a zip tie / ducktape / hondabond. should fix this.
Old Feb 20, 2007 | 01:11 PM
Default Re: (LunchboxZT)
no its very visable i just cant see under the plug... im sure ill be able to fix it when i get home... thanks to all
hondaganja
Feb 16, 2010 12:40 AM
{EF9} GrEaZe m0nKeY
Dec 1, 2009 06:27 AM
modulo_s
Honda Civic (2006 - 2015)
10
Nov 2, 2009 06:38 PM
stockgreencivic
Jan 30, 2004 04:24 AM
