skunk stage 2 cams or crower stage 2's
Old Feb 19, 2007 | 06:26 PM
usdmblackcivic's Avatar
Default skunk stage 2 cams or crower stage 2's
i have 91 crx with a b18c5 swap.been looking for my next upgrade when i came across this guy sellin these cams....know with a stock c5 would i have to upgrade spring and retainers or will she be fine..secound what would be the better cam the skunk stage 2 i can get for 400 and the crower stage 2's i can get for 350..
Old Feb 19, 2007 | 06:37 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: skunk stage 2 cams or crower stage 2's (usdmblackcivic)
I would do a search since there are mountains of information on cams for that engine on this site.
You will absolutely need to change the valve springs.
Old Feb 19, 2007 | 07:08 PM
b16nonoy's Avatar
Default Re: skunk stage 2 cams or crower stage 2's (00Red_SiR)
I have got skunk2 pro 2's...havent reved high enough yet to feel vtec though..
Old Feb 20, 2007 | 05:03 PM
i been loking on here and cant find anything on thu..
Old Feb 20, 2007 | 07:52 PM
RaceCarRyne's Avatar
Default Re: (usdmblackcivic)
the skunk 2 pro 2 will be alot more agressive than the crower 2. there for you will need more compression for the skunk pro 2
Old Feb 21, 2007 | 12:53 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: (DC2jdmIntegra)
I believe he said he was looking at the Stage 2's not pro 2's. Stock compression will work but 11:1 or better is what Skunk recomends for those cams.
Old Feb 22, 2007 | 07:37 PM
koo im starting to think i should leave the c5 stock.
Old Feb 22, 2007 | 08:50 PM
strict 9 ef's Avatar
skunk2 for 50 bucks more i would get them
but i love my crower 2
great mid range cam to top end cam
Old Mar 24, 2007 | 05:53 PM
Sirfallsalot243's Avatar
Default Re: skunk stage 2 cams or crower stage 2's (strict 9 ef)
Skunk2 Stage 2 and Crower Stage 2 are COMPLETELY different cams. The Sk2S2's are BIGGER than Crower Stage 3's! I have the Crower Stage 3's. You can run the stage 2's without upgrading the valvetrain- i know many people who have, and one person who has 25k miles on his with stock valvetrain.
Old Mar 24, 2007 | 06:16 PM
Jay_Sensing's Avatar
JR, I absolutely love my s2s2's but I wouldn't recommend them at all on stock springs.
Plenty of people have done a lot of things that "have worked for them for 100k miles" but that doesn't mean you will be a lucky one.
Old Mar 24, 2007 | 06:32 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: (Jay_Sensing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jay_Sensing &raquo;</TD></TR><TR><TD CLASS="quote">JR, I absolutely love my s2s2's but I wouldn't recommend them at all on stock springs.
Plenty of people have done a lot of things that "have worked for them for 100k miles" but that doesn't mean you will be a lucky one. </TD></TR></TABLE>
I'm pretty sure he was refering to the Crower stage 2's not the S2S2's that would absolutely require valve spring upgrades. From the sounds of it, the Crower stage 2's would be similar to the S1S1's or less, which don't require valvetrain upgrade.
Old Mar 24, 2007 | 06:37 PM
You are correct, I misread that.
I am a valvetrain worrier.
I personally have never destroyed anything but I know plenty who have by under building and I would hate it to happen to a friend.
Hell, if the crowers are smaller than s2s1, then they wouldn't be much different than ITR's anyway would they? I am not too familiar with OEM cam specs.
Old Mar 24, 2007 | 10:13 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jay_Sensing &raquo;</TD></TR><TR><TD CLASS="quote">You are correct, I misread that.
Hell, if the crowers are smaller than s2s1, then they wouldn't be much different than ITR's anyway would they? I am not too familiar with OEM cam specs.</TD></TR></TABLE>
You are correct, the Crower 2's are similar in lift and duration to the ITR cams. The non-vtec lobes are a bit bigger though, which creates better bottom and mid, but a worse idle and higher VTEC engagement.
My Stage 3's dont have VTEC engagement until 5900 rpm (4400 being stock on a B18C1).
Old Mar 24, 2007 | 10:21 PM
Rollo Lawson's Avatar
Default Re: (Sirfallsalot243)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sirfallsalot243 &raquo;</TD></TR><TR><TD CLASS="quote">You are correct, the Crower 2's are similar in lift and duration to the ITR cams.</TD></TR></TABLE>
ummmmmmm.........no.
Old Mar 25, 2007 | 06:03 AM
That was extremely helpful Rollo, in the spirit of tech, would you mind enlightening us with numbers or are you just sticking with a vague "ummmmmmm.......no" because it helps you sleep at night to play I have a secret?
Old Mar 25, 2007 | 07:00 AM
autox228's Avatar
https://honda-tech.com/zero...56856
Old Mar 25, 2007 | 08:45 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jay_Sensing &raquo;</TD></TR><TR><TD CLASS="quote">That was extremely helpful Rollo, in the spirit of tech, would you mind enlightening us with numbers</TD></TR></TABLE>
CTR cams
Intake-duration @.050" = 240 lift w/1.55 = 447
Exhaust @ .050" = 232 lift w/1.55 = 416
Crower Stage 2
Intake duration @ .050" = 255 lift w/1.55 = 466
Exhaust @ .050" = 248 lift w/1.55 = 466
here you go.
Old Mar 25, 2007 | 12:46 PM
Default Re: (Rollo Lawson)
A bit more lift, but the duration is almost the same. (what point would there be for Crower to make cams identical to ITR cams?)
CTR
Int- 294 mid
Exh-305 mid Int- 240 mid
Exh-232 mid Int- 447 mid
Exh-416 mid
Crower 2
Int- 311 mid
Exh-308 mid Int- 255 mid
Exh-248 mid Int- 466 mid
Exh-466 mid
Old Mar 25, 2007 | 02:39 PM
[QUOTE=Sirfallsalot243]A bit more lift, but the duration is almost the same. [QUOTE]
buddy, you are missing the point. you'd be hard perssed to find other cam manufacturers that equate rocker ratios into the equation like Crower. so, when you see other manufacturers advertising 265-270 degrees of duration, that is measured at a higher spec. include the r.ratio and the specs decrease.
alexthegrinch
13
Jun 17, 2009 05:08 PM
vitalik
Sep 12, 2006 06:02 PM
an2ny888
Jan 23, 2005 06:48 PM
2.2SICKLUDE
38
Nov 18, 2003 01:19 PM
LX4SI2NV
Jan 21, 2003 02:09 PM
