control arm
Old Feb 19, 2007 | 05:54 PM
red beast's Avatar
Default control arm
i just bought a rear disc brake setup for my 96 civic coupe from a local junk yard. the guy said it came from a 97 coupe. but the problem is that i am not sure if the setup is from a si or a integra, as i want to buy a set of skunk2 rear control arms, but i am not sure if the rear control arms from the si and integra is the same
Old Feb 19, 2007 | 06:00 PM
Chim Chim's Avatar
Default Re: control arm (red beast)
Get the control arms that fit your chassis... I.E. if you have an Integra, get the Integra arms. They should also fit the EG... If you have an EK, get the EK arms. The trailing arms are essentially all the same. Seeing that you have a 96, get the control arms for a 96-00 civic...
Old Feb 19, 2007 | 06:06 PM
B16B_coupe's Avatar
HRD PKR
Default Re: control arm (Chim Chim)
if u have a 96 get 96-00 rear upper control arms and lower.. only the front lower ones are diff in the front between some models...
just make sure u use your own alignment arm and ur control arms
Modified by B16B_coupe at 8:16 PM 2/19/2007
Old Feb 19, 2007 | 06:50 PM
Richard...'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chim Chim &raquo;</TD></TR><TR><TD CLASS="quote">trailing arms are essentially all the same. Seeing that you have a 96, get the control arms for a 96-00 civic... </TD></TR></TABLE>
existanzcivicb20
Suspension & Brakes
Apr 22, 2015 02:26 PM
slammed95lude
Apr 12, 2007 05:52 PM
4drgsr96
Oct 24, 2006 07:20 AM
CivicHb04
Dec 23, 2003 09:56 AM
E-AT_me
Aug 15, 2002 08:16 AM
