my axle came apart
well im not sure if the axle came apart but an hour or so ago...i was putting on coilovers and i didnt put pressure under the rotor and this "loosing air" sound came from the cv boot and now it wont go back into place
The inner joint? You can remove the large band, pop the boot off, and then you'll see the bearings that slip into grooves in the joint housing. Most parts stores have universal band clamps in stock.
Hole in the boot? you don't want all the grease to sling out when driving; The parts store should have the kit with the boot and clamping bands.
Inner or outer?
Inner or outer?
BigDawwg6969
13
Jan 5, 2004 07:12 PM
