Help calculating bearing thickness..
Old Feb 19, 2007 | 05:05 PM
litovi3tboi503's Avatar
Default Help calculating bearing thickness..
Is there any write up on how to measure for bearing thickness? I saw the one that earl had a write up on bearing clearence what about thickness? please help.. thanks
Old Feb 19, 2007 | 05:28 PM
Boner_Ben's Avatar
Default Re: Help calculating bearing thickness.. (litovi3tboi503)
Main Bearing thickness by color
Blue 2.013-2.010 mm 0.0793”- 0.0791”
Black 2.010-2.007 mm 0.0791”- 0.0790”
Brown 2.007-2.004 mm 0.0790”- 0.0789”
Green 2.004-2.001 mm 0.0789”- 0.0788”
Yellow 2.001-1.998 mm 0.0788”- 0.0787”
Pink 1.998-1.995 mm 0.0787”- 0.0785”
Red 1.995-1.992 mm 0.0785”- 0.0783”
Rod bearing thickness by color
Blue 1.510-1.507 mm 0.0594”- 0.0593”
Black 1.507-1.504 mm 0.0593”- 0.0592”
Brown 1.504-1.501 mm 0.0592”- 0.0591”
Green 1.501-1.498 mm 0.0591”- 0.0590”
Yellow 1.498-1.495 mm 0.0590”- 0.0589”
Pink 1.495-1.492 mm 0.0589”- 0.0587”
Red 1.492-1.489 mm 0.0587”- 0.0586”
earl
Engine Machining & Assembly
Jun 8, 2012 09:38 AM
hondaapi
Nov 23, 2005 04:29 AM
mandopr77
Jun 4, 2004 05:26 PM
earl
Dec 25, 2003 10:04 PM
