Sup guy identify object i know its a manifold just where does it come from???
Old Feb 19, 2007 | 03:55 PM
slayerfromhell212's Avatar
Default Sup guy identify object i know its a manifold just where does it come from???
yeah i was wondering where this manifold comes from i know its from a d-series but i was wondering if it would fit a d15b7 with v-tec head and whats better this or the regular 1 from the d15b7?
Old Feb 19, 2007 | 03:57 PM
alacard's Avatar
looks like one off of a 96-00 hx? possibly...someone confirm this.
Old Feb 19, 2007 | 04:02 PM
Default Re: (alacard)
It can be but, is it better than a d15b7 manifold?
Old Feb 19, 2007 | 04:05 PM
pdiggitydogg's Avatar
That looks like a y8/y5 manifold (auto: fitv)
Its the "type r manifold of d series"....so they say...
yeah, better than the d15 mani
Old Feb 19, 2007 | 04:06 PM
slo6gen's Avatar
ex manifold
Old Feb 19, 2007 | 04:11 PM
Default Re: (pdiggitydogg)
its auto ? so it would it fit a manual ?
Old Feb 19, 2007 | 04:28 PM
KevronsEG's Avatar
Default Re: (slayerfromhell212)
It will fit. all D manifolds bolt up with in 88-00
The Z6 is the best D stock manifold it beats teh Y8 out.
Old Feb 19, 2007 | 04:30 PM
I Have an STD's Avatar
wrenchin'
rewiring is required to make it function correctly. notice the lack of an IACV?
Old Feb 19, 2007 | 05:19 PM
KevronsEG's Avatar
Default Re: (I Have an STD)
word i totaly missed that good catch STD
Old Feb 19, 2007 | 05:26 PM
pro-driver22's Avatar
Default Re: Sup guy identify object i know its a manifold just where does it come from??? (slayerfromhell212
that manifold is the best d series manifold ever
Old Feb 19, 2007 | 05:35 PM
Skunk.Werks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pro-driver22 &raquo;</TD></TR><TR><TD CLASS="quote">that manifold is the best d series manifold ever</TD></TR></TABLE>
No it's not, there are dyno charts proving that the Z6 is superior.
Old Feb 19, 2007 | 05:50 PM
Chim Chim's Avatar
That's definitely a Y8 auto manifold that comes from a 96-98 EX. The 99-00 has the air injection which are little holes in the flange just above the runners with a vacuum fitting on top of the flange. The y5 manifold from the HX has an EGR which is a big plate that spans across the runners which is fairly easy to spot. Should you decide to go with a Z6 manifold, I'd gladly take that off your hands...
Old Feb 19, 2007 | 05:59 PM
big-cat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chim Chim &raquo;</TD></TR><TR><TD CLASS="quote">That's definitely a Y8 auto manifold that comes from a 96-98 EX. The 99-00 has the air injection which are little holes in the flange just above the runners with a vacuum fitting on top of the flange. The y5 manifold from the HX has an EGR which is a big plate that spans across the runners which is fairly easy to spot. </TD></TR></TABLE>
+1 for you. installed one on my y7 head, you will not notice a difference and it is a pain in the ***. have fun.
Old Feb 19, 2007 | 07:49 PM
Chim Chim's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by big-cat &raquo;</TD></TR><TR><TD CLASS="quote">
+1 for you. installed one on my y7 head, you will not notice a difference and it is a pain in the ***. have fun. </TD></TR></TABLE>
I'm sure it'll help out once you go FI...
Old Feb 19, 2007 | 09:54 PM
how much would you give me for the manifold?
ok its an auto whats the correct way that if there is to make this for a manual ?
anything with links will help me or any help from the h-t team thnks
Modified by slayerfromhell212 at 11:55 PM 2/19/2007
Old Feb 19, 2007 | 11:22 PM
Chim Chim's Avatar
Assuming your current setup uses a 2 wire IACV, you'd have to drill and tap the manifold for that which is more hassle than it's worth for most people. A Z6 manifold already uses a 2 wire IACV on both the manual and automatic as far as I know and is the better manifold as stated by other HT members.
That y8 auto manifold you have pictured is a more straight foward swap on a y7 than it would be on a d15b7 because all y7's use a 3 wire IACV where as the y8 manual uses a 2 wire version.
Old Feb 19, 2007 | 11:57 PM
nicely said want to buy it off me?
Old Feb 20, 2007 | 12:08 AM
7808's Avatar
whys the z6 better then the y8 manifold?
Old Feb 20, 2007 | 05:21 AM
md88hfcrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skunk.Werks &raquo;</TD></TR><TR><TD CLASS="quote">
No it's not, there are dyno charts proving that the Z6 is superior.</TD></TR></TABLE>
prove it.
Old Feb 20, 2007 | 05:56 AM
Bakeoff's Avatar
Ummm, you notice that the TPS is broken and the TB had a fitting pulled out of it?
That thing is in rough shape. You could clean it up, but why? If you're using the Z6 manifold, keep it.
Old Feb 20, 2007 | 12:08 PM
i have another tps and its in gd condition yes im going to be cleaning the manifold today and you said a fitting was pulled out well ill just get it ahah
Old Feb 20, 2007 | 12:57 PM
Midori Green's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7808 &raquo;</TD></TR><TR><TD CLASS="quote">whys the z6 better then the y8 manifold? </TD></TR></TABLE>
notice the y8 manifold is extremely thick.... which equals more air.... which equals more power....which equals better. not much but there is a difference in air intake... if the z6 was better honda would have kept using it on the ex model... the y8 has less restrictions.
Old Feb 20, 2007 | 01:10 PM
This guy is talking out his ***... he probably owns a z6 manifold and wont admit that the y8 is better... and by the way I dont own either of them.
Old Feb 20, 2007 | 03:01 PM
big-cat's Avatar
there are rumors lingering that someone did the test and supposebly the z6 is a better manifold though the plenum on the y8 is prob better for f/i.
Old Feb 20, 2007 | 04:33 PM
7808's Avatar
Default Re: (big-cat)
i always thought that the y7 would be a good FI manifold cause it would flow more evenly. its dumb tho i turbo'd a y7 once its anoying to deal with
